Resultant forces of coplanar systems
The discussion revolves around determining the magnitude of force F in a coplanar system where the resultant of three forces passes through point O. Participants emphasize the importance of understanding the resultant force's relationship to moments around point O, suggesting the use of Varignon's theorem. The problem is clarified as not necessarily being in equilibrium, which affects the approach to finding F. Despite attempts to sum forces and resolve components, the correct answer is identified as 19.9 kN, highlighting the need to focus on the resultant force's definition and its implications for moments. The conversation underscores the complexity of analyzing forces in non-equilibrium systems.
SUCRALOSE
Determine the magnitude of F if the resultant of the three forces passes through point O.
ƩFx = 0
ƩFy = 0
ƩM = 0
The most I can come up with is that the two forces on the left would equal F on the right, and trying to ratio the force and distance it still does not work.
Any hints would be greatly appreciated.
Likes Jacob Sigging
540 views and no one person on here can even throw a simple hint my way... I am at a loss as to why. I read the rules and have done everything instructed. What's the deal here?
Can you explain the diagram a bit. Is it some rigid structure that is in equilibrium?
If it's in equilibrium, I think you can sum up moments at O and resolve F to its x and y components and find the moment due to each component. Or you could just sum up forces along x and y to 0 (but since there's no angle I think you should use the moment method).
**Just noticed you need the resultant force.. I think you should use Varignon's theorem.
Thanks for the replies,
The question states, "determine the magnitude of the vertical force F if the resultant of the three forces acting on the crank passes through the bearing O."
So if it's a crank and the resultant is passing through a bearing then it is not in equilibrium, I am assuming.
I have tried summing the forces on the right side and converting that into it's x & y coordinates, but that does not work. I have worked out all angles and have tried lots, but nothing has worked.
The answer is 19.9 kN, just can seem to find out how to get to that.
You're right, its not necessarily in equilibrium. Luckily, you don't need to know if its in equilibrium to answer the question. The key is in the definition of the resultant force (which I just looked up to try to get my head round it). The question says that the resultant force passes through O, so what does this tell us about the sum of the moments around O?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
