Conservation of Angular Momentum in a Rotating System
The discussion centers on a physics problem involving a rotating turntable and a blob of clay, focusing on the conservation of angular momentum. Participants clarify that the moment of inertia is crucial for calculating the system's new angular speed after the clay is added. The initial angular momentum of the turntable must equal the final angular momentum of the combined system to find the resulting angular speed. There is confusion regarding the relationship between angular speed and moment of inertia, emphasizing the need for understanding these concepts in rotational dynamics. The conversation highlights the importance of applying conservation laws to solve problems involving rotating systems.
physics123456
A circular turntable of mass 2.0 kg and radius 6.0 inches is rotating freely at 66 2/3 rpm. If a 500 gram blob of clay is dropped on the disk at a distance of 4.0 inches from the center, what is the resulting angular speed of the system? Treat the clay as a point mass (I = MR^2) and the turntable as a disk.
I understand the resulting angular speed will be the sum of the two. But what does moment of inertia have to do with it??
What do you mean about the angular speed being the sum of the two? Doesn't sound right.
What relevant conservation law do you know?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
