Retarding Force and Velocity of a Sliding Rock
  • Thread starter Thread starter carlee172
    Force
A rock sliding on a horizontal surface experiences a retarding force proportional to the square root of its instantaneous velocity, described by the equation FR = -kv^(1/2). To find the velocity as a function of time, the relationship F = ma is applied, leading to the differential equation -k√v = m(dv/dt). The discussion emphasizes the need to separate variables before integrating to solve for v in terms of time, mass, the constant k, and initial velocity v0. The initial attempts to express v resulted in equations that incorrectly included v on both sides, indicating a need for proper integration techniques. Ultimately, the focus is on deriving a correct expression for velocity that allows calculation based on the given variables.
carlee172
A rock with mass m slides with initial velocity vo on a horizontal surface. A retarding force FR that the surface exerts on the rock is proportional to the square root of the instantaneous velocity of the rock FR=-kv1/2.
A) Find expression for the velocity of the rock as a function of time.
Express your answer in terms of the variables m, vo, k, and t.
F=ma
v=vo +at
etc..
vbasically included solving and substituting F=ma, FR=-kv1/2 and v=vo +at
in the end i got v=vo -kv1/2t/m
obviouslt this isn't right because i have v on both sides of the equation.. help
Welcome to PF.
v=vo +at doesn't work here, because you need a constant acceleration for that equation.
F=ma is a good start. You'll also need to use some calculus to solve this one.
ok, so:
-k\sqrt{}v=m(dv/dt)
then integrate the first side from 0 to t and the left side from vo to v
and then solve for v, i got:
v=((-kt-2(v1/2)m)/2m)2
ok so i got the answer v=(4m2v0-4ktmv1/2+k2t2)/4m2
now, i have to find the integral (distance). for t, the rest are constants i guess
One problem with that expression is that it's supposed to be an expression for v in terms of t and the other variables, i.e. given t, m, k, and v0, you should be able to calculate v.
But you have v there on the right-hand-side, so it's not really an equation for v.
carlee172 said:
ok, so:
-k\sqrt{}v=m(dv/dt)
Let's go back to this equation. I didn't really follow what you did after that, but I would separate the two variables, v and t, before integrating. I.e., put all the v's (including the dv term) on one side of the equation, and put dt on the other side. Then integrate.
