Find Heat, Work & Internal Energy for Reversible Expansion of Gas
sachi
we have an ideal monatomic gas which intially occupies 27*(10^-3) m^3 at a pressure of 3.2*(10^5) Pa and at a temperature of 400K. We have to find the heat supplied to the gas, the work done on it, and its increase in internal energy when it is compressed isothermally at 400K to a volume of 8*(10^-3) m^3.
We were given a standard solution to this question which works out work done using W=-P*dV. I think this is incorrect, though as work done is a function of state and therefore is path dependent, so we would need to be informed that the path was reversible before we could figure out the work done in this way. We know the change in T=0, and for ideal gas U=U(T) therefore change in U is zero, therefore by 1st law W=-Q, so we can find a relationship between the two but can't calculate anything explicitly. I think this is right but am not sure.
Also, I'd like to discuss the fact that W>-PdV for irreversible changes. I can't quite get my head around the inequality. If a gas was to expand by a certain volume reversibly, then it would do a certain amount of work on the surroundings. If it was to expand irreversibly it would have to do the same amount of work on the surroundings to expand in volume, but it would also have to do work against frictional forces. Therefore the amount of work would have greater modulus but -ve sign. Surely then dW <-P*dV??
Thanks very much.
Using the first law, of course:
\Delta Q = \Delta U + \Delta W
As you noted, since there is no temperature change, the internal energy of the gas does not change (\Delta U = \frac{3}{2}nR\Delta T for a monatomic gas). So:
\Delta Q = \Delta W = \int_{Vi}^{Vf} P dv
Since PV = nRT, P = nRT/V = P_iV_i/V.
\Delta W = P_iV_i\int_{Vi}^{Vf} \frac{dv}{V} = P_iV_i ln\frac{V_f}{V_i}
Thanks very much.
The definition of work is Force x Distance so, by definition, dW = Fds = PAds = PdV (static pressure). So, this is always true whether it is a reversible or irreversible change. If the change is reversible, the work done to or by the gas is recoverable. If it is not recoverable, it is irreversible. But dW is always equal to PdV (assuming thermodynamic equilibrium).
Hope that helps.
AM
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
