RL parallel circuit. No value given
76 replies · 10K views · last reply
just wonder is 1 or -1 ?
if -1 then 63.43°
magnitude is (-2jRXL) / (R^2+XL^2) Vertical = imaginary
angle is (v/2) * [ (R^2 - XL^2)/(R^2+XL^2) Horizontal = real
It seems that you don't know what is meant by magnitude or angle of a vector?
A complex number can be regarded as a vector with its real part drawn horizontally and the imaginary part drawn vertically. The magnitude is the length of that vector.
hi Nascent ,would the magnitude be √( (R^2-XL^2)^2+ (-2jRXL)^2)?
while the angle be θ=(tan^-1(-2jRXL/(R^2-XL^2)))° ?
cheers :)
No, you have left out something major.
while the angle be θ=tan^-1(-2jRXL/(R^2-XL^2))° ?
There is no j in either magnitude or angle. You drop the j. There won't be a degree symbol where you wrote it, either.
is it the denominator (R^2 + XL^2) ?
ok so would the magnitude be
√( ((R^2-XL^2)/(R^2+XL^2))^2 + (-2RXL/(R^2+XL^2)) ^2 )?while the angle be θ=tan^-1(-2RXL/(R^2-XL^2)) ?
Wasn't there a factor of 2 in the denominator?
while the angle be θ=tan^-1(-2RXL/(R^2-XL^2)) ? ✔[/size][/color]
√(((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 ) or
√(((R^2-XL^2)/(2R^2+2XL^2))^2 + (-RXL/(R^2+XL^2)) ^2 )
Sam 007 said:
√(((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 ) ? how about now :)
That looks right. You could take out the common denominator.
There is supposed to be a V in front of all that, too, if this is Va-Vb.
so the magnitude = V sqrt of ((R^2-XL^2)/(2R^2+2XL^2))^2 + (-RXL/(R^2+XL^2)) ^2 )
that's it right? :D
hmm should it be since its the magnitude of Vab
V*√(((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 ) or
√(V*((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 ) or
√(V^2*((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 ) ?
that's it right? :D
Yes.
for f) calculate the power factor of the circuit.
power factor = true power / apparent power which is (I^2 *R) / (I^2 *Z)
so i can use the equation in c) which is the active power dissipated in each resistance divide by d) which is the reactive power dissipated in XL by using power factor formula.
am i right ?
V·√(((R^2-XL^2)/(2R^2+2XL^2))^2 + (-2RXL/(2R^2+2XL^2)) ^2 )
Something seems wrong.
That whole expression simplifies to V/2. That can't be right? But I think it is right!
That makes things easier! :smile:
am i right ?
c) active power dissipated in each resisance
formula p=(I^2)*R
[( V∠0 (3R+Xl∠90 )) / ( 3R+2RXl∠90 )]^2 *R
d) reactive power dissipated in XL
Q=I^2 * jXL
[( V∠0 (3R+Xl∠90 )) / ( 3R+2RXl∠90 )]^2 * Xl∠90
so for Power Factor
P/Q =
[(( V∠0 (3R+Xl∠90 )) / ( 3R+2RXl∠90 ))^2 *R] / [(( V∠0 (3R+Xl∠90 )) / ( 3R+2RXl∠90 ))^2 * Xl∠90 ]
is it correct ? :)
formula p=(I^2)*R
yes
But I don't like the look of that.
Q=I^2 * jXL
Yes, without the j.
I don't think so.
You will have to work out the current through the R-XL branch in order to determine the power in that resistor, and reactive power in that XL. Use complex algebra (real + j imaginary) to do this, since you've learned that method.
C) active power in each resistor?
P=V^2/R1
P=V^2/R2
P=V^2/R3
XL has no active power
D) Reactive power?
Q= V^2/XL
E) Total current
It=V/R1+V/R2+V/R3+V/XL
not sure?
for d)
Q=|V^2| / XL
v= (jXL / (R + jXL)) *v -> voltage divider rule.
v= (jVXL)/ (R+ jXL)
v^2 = [ (jVXL)/ (R+ jXL) ] ^2
v = (j^2 V^2 XL^2) / ((R + jXL)^2)
v= (-V^2 XL^2) / ((R + jXL)^2)
so sub V into Q=|V^2| / XL
Q= [(-V^2 XL^2) / ((R + jXL)^2)] / XL
Q= (-V^2 XL^2) / (XL*((R + jXL)^2)) ->VAR
am i right? :/
P=V^2/R1
P=V^2/R2
P=V^2/R3
D) Reactive power?
Q= V^2/XL
E) Total current
not sure?
for c) we not need to calculate the total P ? just P in each resistance ? :rolleyes:
and for b) we just use the magnitude of Vab and how about the XL ?
I don't really think you have to use Vab from part B for part C just the voltage V∠0°
Yeah for part C. just calculate the power in each resistance, XL is not a resistor its an inductor has no resistance.
But than again I am not sure will have to ask nascent
thank you.
but if i want to find the total active power ? what will it be..
and can u solve d)? I am not sure I am doing correctly.
well this is the way I would do it but stephanie I think it may not be right
P=V^2/R1+V^2/R2+V^2/R3
this is what i got as well.
That could only be right iff there is a voltage of amplitude V across each individual element, R1, R2, and R3, and there isn't. None has V volts across itself.
But for the series pair R-R you can say V volts exists across that pair.
stepfanie said:
for d)
Q=|V^2| / XL
https://www.physicsforums.com/images/icons/icon14.gif That's the right way for finding the voltage across the inductance. Now convert this to a vector having a magnitude and an angle. Power calculations involve the square the magnitude of the voltage across any element. https://www.physicsforums.com/images/icons/icon6.gif
