Rocket Engine Combustion Chamber Equations
Designing a combustion chamber for a rocket engine requires understanding specific equations and dimensions, which are not easily found in standard resources. The SSME (Space Shuttle Main Engine) serves as a reference, featuring an area ratio of 69:1, a chamber pressure of 2,994 psia, and an engine mixture ratio of approximately 6.0. NASA's RAMP program and proprietary codes from Rocketdyne are used for nozzle design analysis. Resources like AIAA publications can provide valuable insights into combustion chamber and nozzle design. Proper design involves correlating the chamber's length and diameter with the nozzle dimensions for optimal performance.
FiggyOO
Good evening all,
I was wondering if anyone would be able to point me in the right direction to equations in regards to designing a proper combustion chamber for a rocket engine, as well as for the throat/De Laval nozzle as well. I've looked around and I can't seem to find anything that covers the actual dimensions of the chamber.
I don't think things are just as easy as using equations & feeding numbers for designing purpose.
This might be useful.
http://www.pwrengineering.com/articles/nozzledesign.htm
NASA Marshall used a program called RAMP to analyze nozzle designs. I would expect Rocketdyne (now part of United Technologies/Pratt & Whitney) used their own proprietary code.
Search Google or other search engine with "SSME","nozzle"
The SSME uses an H2-rich mixture.
AIAA has a number of books on propulsion, including some description of combustion chambers, throats, and nozzles.
Thanks, I know there are equations to make a proper combustion chamber though. I know that the chamber needs to be a certain length and diameter in relation to the nozzle.
One could take a cross-section and simply plot diameter or radius of nozzle as a function of distance from throat.
For SSME -
Area Ratio: 69:1
Chamber Pressure: 2,994 psia
Engine Mixture Ratio: 6.0 (IIRC, mass O2/mass H2)
Dimensions
Length: 168 in.
Diameter: 96 in.
http://www.enginehistory.org/SSME/SSME1.pdf
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
