Roots of a squared polynomial ( complex numbers)
Axe199
problem in a pic attached
i solved i and ii a , when it came to b , i just said that every one of the 3 roots will be squared having 2 roots 1 + and 1 - but then i read the marking schemes ( also attached) , and i got really confused and now i don't know what he wants from me
  • 2014-04-03 19_12_33-papers.xtremepapers.com_CIE_Cambridge International A and AS Level_Mathemati.png
  • 2014-04-03 19_16_42-papers.xtremepapers.com_CIE_Cambridge International A and AS Level_Mathemati.png
He wants you to tell him what are all the square roots of -2, -2+2*sqrt(3)*i and -2 - 2*sqrt(3)*i.
why can't i just say (z+2)^2= 0 and solve and do the same for the complex roots?
why do i have to find the roots of the -2?
(z + 2)2 is not a factor of p(z2). It is a factor of (p(z))2, however, a completely different polynomial.
The polynomial is not the object being squared. p(z2) only means that the variable z is being replaced with the variable z2. So, as a result, we know that z2 + 2 is a factor.
Likes 1 person
okay...thanks very much, tht was a tricky one, or maybe i am stupid :D
either way , thanks , i got it
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
