Rotating a line anticlockwise about P
  • Thread starter Thread starter rellenayyy
    Line Rotating
rellenayyy
Find the resulting equation of the line ax+by=c after rotating it anticlockwise by theta degrees about the point P(x0,y0) using the applications of the rotation matrix.
you should be able to multiply it by a rotation matrix. Do you know what this is?
not really.. i need the equation of the new line though. I'm not quite sure how to go about this.. please help?
you need to translate the line so that its origin is at (x0, y0) then rotate and then translate the line back. You should be able to multiply these different matrices to obtain one matrix. Does this make sense?
I think you should look up matrix transformations if you still don't understand.
oh okay thank you. do you have know of a site at all that i may be able to refer to for extra help ?
http://wally.cs.iupui.edu/n351/3D/matrix.html
hope it helps
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
