Rotation dynamics, dealing with impulse and oscillation
Andreas
A homogene rod with length "l" is placed vertically, and a nail is stabbed on the top of the rod (now the rod has an axis). And then an impulse is given on the rod with the separation between the impulse given to the rod's axis is "d". Earth gravitational acc is represented as g, the mass of the rod is m. Now, calculate the minimum value of d to make the rod rotate 360°.
Now if the condition above is complete, and the rod make a harmonic movement (oscillation) what is the period?
And what is the length of a mathematical pendulum should be to make the same period with the oscillating rod?
I.ω = m.ω.d2
T= 2∏√(I/mgR)
2∏√(mgR/I) = 2∏√(l/g)
First I take the conservation of angular momentum with the first relevant eq.
I.ω = m.ω.d2
where I of the rod is 1/3ml2
1/3ml2ω=mωd2
d2=1/3l2
d=1/3√3l
Please correct me if I'm wrong and also the solution for the second and third question
Hello Andreas, and welcome to PF.
Could you clarify a few things for me:
Is this the complete formulation of the exercise ?
I wonder how a minimum for d can be calculated if there is no further information about the "pulse".
And: what is the first relevant equation ?
And: what is R in the second and third ? (probably the answer to the third question?)
Then, in the solution: how does this show that the rod rotate at least 360 degrees ? And why is g absent in the answer ?
For the second question, what does "if the condition above is complete" mean ? The way I read it it would mean there is no harmonic motion at all: once it has passed the 180 degrees it will just keep spinning (in the absence of friction).
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
