Rotational Kinematics of bicycle breaks
The discussion focuses on solving problems related to rotational kinematics involving a bicycle and a roulette wheel. For the bicycle, the correct approach to find the time to stop and angular acceleration involves using the equations for uniformly accelerated motion, converting revolutions to radians for accurate calculations. The solution reveals that it takes 9.42 seconds for the bicycle to come to rest, with an angular acceleration of -1.91 rad/s². In the second problem, the initial angular velocity of the roulette wheel is determined to be 52.5 rad/s, leading to a calculated angular displacement of 269.5 radians. The thread emphasizes the importance of using the correct equations and unit conversions in rotational motion problems.
tem_osu
[SOLVED] Rotational Kinematics
A person is riding a bicycle, and its wheels have an angular velocity of +18.0 rad/s. Then, the brakes are applied and the bike is brought to a uniform stop. During braking, the angular displacement of each wheel is +13.5 revolutions.
(a) How much time does it take for the bike to come to rest?
(b) What is the angular acceleration of each wheel?
(a) θ = (ω0 + ω)t
(b) ω = ω0 + αt
(a) +13.5 rev = (18.0 rad/s - 0 rad/s)t
t = (+13.5 rev)/(18.0 rad/s) = 0.75 - wrong answer
(b) (ω - ω0)/t = α
(0 rad/s - 18.0 rad/s)/0.75 = α - wrong answer
After 10.0 s, a spinning roulette wheel at a casino has slowed down to an angular velocity of +1.70 rad/s. During this time, the wheel has an angular acceleration of -5.05 rad/s^2. Determine the angular displacement of the wheel.
ω^2 = ω0^2 + 2α(θ − θ0)
(+1.70 rad/s)^2 = 0 + 2(-5.05 rad/s^2)θ
θ = [(1.70 rad/s)^2]/2(-5.05 rad/s^2) = -0.286 - wrong answer
Please help me, I don't know what I'm doing wrong.
Start with 1). Your equation a) is wrong. This is accelerated motion. The equation should be:
theta=omega_0*t+(1/2)*alpha*t^2. Solve your equation b) for alpha and substitute that into a). Now the only variable is t.
(a) θ = (ω0 + ω)t
(b) ω = ω0 + αt
The equation you have listed as (a) is only valid for uniform angular velocity. Since the wheel is slowing down, velocity is not constant, so you have to use an equation for uniform acceleration (since the problem states that the wheel comes to a uniform stop).Since the acceleration is uniform, you can assume that \alpha = \frac{\Delta\omega}{\Delta t}.
equation 1: θ = ω0t + 1/2αt^2
equation 2: ω = ω0 + αt
(ω - ω0)/t = α
solve for α from equation 2 & plug into equation 1:
θ = ω0t + 1/2[(ω - ω0)/t]t^2
θ = ω0t + 1/2[(ω - ω0)]t
13.5 = 18.0t + 1/2(0 - 18.0)t
13.5 = 18.0t - 9t
13.5 = 9.0t
t = 1.5 seconds - but it's still wrong
Did I simplified it wrong?
A 'rev' is not a 'rad'. How many radians is 13.5 revolutions? Other than that, well done.
(a) 13.5 x 2Pi = 9.0t
t = 9.42 s
(b) (0-18.0 rad/s)/9.42s = -1.91 rad/s^2
Thank you so much.
I'm still confuse about the second problem though. I tried several ways, but I've gotten some weird answers.
omega_0 in that problem isn't zero. The wheel starts at velocity omega_0, slows down at a rate of -5.05rad/sec^2 for 10 sec. Then it's speed is 1.7rad/sec. Can you figure out the correct value for omega_0. Think about it...
ω = ω0 + αt
ω - αt = ω0
(1.70 rad/s) - (-5.05 rad/s^2)(10.0 s) = ω0
ω0 = 52.5 rad/s
ω^2 = ω0^2 + 2αθ
(1.70^2) = (52.2^2) + 2(-5.05)θ
θ = [(1.70^2) - (52.2^2)]/(2 x -5.05) = 269.5 rad
GOT IT!
Thank you so much for helping me. ^-^
