Rotational Kinetic Energy of Moving Wheel
A bicycle with wheels of radius 0.25 m and rotational inertia of 0.096 kg*m² has a total mass of 79 kg. The discussion focuses on finding the fraction of the total kinetic energy that is attributed to the rotational kinetic energy of the wheels while coasting at constant speed. Participants clarify that the total kinetic energy should be calculated by summing the rotational energy of the wheels and the translational energy of the bicycle. It is emphasized that the actual values for speed are not necessary for determining the ratio, as variables will cancel out in the calculations. The conversation highlights the importance of understanding the relationship between linear and angular velocity in smooth rolling motion.
easchwen
A bicycle has wheels of radius 0.25 m. Each wheel has a rotational inertia of 0.096 kg* m2 about its axle. The total mass of the bicycle including the wheels and the rider is 79 kg. When coasting at constant speed, what fraction of the total kinetic energy of the bicycle (including rider) is the rotational kinetic energy of the wheels?
KE=1/2 Iw^2 KE=1/2 mv^2
I tried using (1/2 Iw^2)*(1/2 mv^2) = total KE, but that didn't seem to work. Help?
1. By " * " did you mean multiplying? It shouldn't be multiplying, it should a plus sign.
2. What you are asked for is the fraction of the wheels' energy; meaning \frac{E_{wheels}}{E_{total}}
3. You have to calculate the sum of the two wheels' energy first. Divide that by the total energy of the whole thing.
yes, I meant a plus sign... my mistake! I still am unsure as to what I should do... I am not given angular velocity or linear velocity so I don't know how to find the energy.
Since you only are asked to find the ratio, you don't need the actual values for the speed. Call the linear speed V. (Hint: You should be able to express the angular velocity in terms of V.)
Well, you don't always have to have all the data. e.g. the mass is a variable but will be canceled out--> E_{g}=K
mgh=\frac{1}{2}mv^{2}
Let me give you a hint. What happens in smooth rolling?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
