How Is Rotational Kinetic Energy Calculated for a Cylinder Rolling Down a Ramp?
To calculate the rotational kinetic energy of a cylinder rolling down a ramp, the moment of inertia formula I = 1/2 mr^2 should be used, as it applies to cylinders, not I = 2/5 mr^2, which is for spheres. The total mechanical energy conservation principle states that the potential energy (mgh) at the top of the ramp converts into both translational and rotational kinetic energy as the cylinder rolls down. The correct kinetic energy equation combines translational KE (1/2 mv^2) and rotational KE (1/2 Iω^2), where ω relates to v through the radius. After finding the velocity using energy conservation, substituting it into the kinetic energy equations will yield the correct rotational kinetic energy. Properly applying these formulas ensures accurate calculations for the cylinder's motion.
map7s
A 2.4 kg cylinder (radius = 0.09 m, length = 0.50 m) is released from rest at the top of a ramp and allowed to roll without slipping. The ramp is 0.74 m high and 5.0 m long. What is its rotational kinetic energy?
I just wanted to make sure that I was on the right track...
I=2/5 mr^2
KE=1/2 mv^2 + 1/5 mv^2
Using conservation of energy: mgh=1/2 mv^2 + 1/5 mv^2 and then solve for v and plug into equation for KE.
Does this sound like I'm doing this correctly?
I=2/5 mr^2
You are on the right track, but you are using the wrong formula for rotational inertia. (2/5 mr^2 is for a rolling ball, not a cylinder.)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
