Calculating Acceleration of Loaded Cart – Friction & Weight Matter?
The discussion centers on calculating the acceleration of a loaded cart being pulled by a force, emphasizing the impact of friction and weight. It highlights that both the mass of the load and the force of friction play significant roles in determining acceleration. The moment of inertia of the wheels is relevant, but the overall mass of the cart and its load cannot be ignored. Real-world scenarios complicate the calculations due to varying frictional forces. Ultimately, understanding both translational and rotational dynamics is crucial for accurate acceleration assessments.
gyshalom
suppose a block with mass m is being pulled by force f,the force of friction (first static then kinetic) will resist its motion.
now, take this block and put it on a cart with wheels and pull it with the same force,when calculating the acceleration of this loaded cart,is it just a matter of calculating rotational and translational motion of the wheels does the wheight of the block on the cart matter when it comes to how fast the cart will accelerate? or is it just the moment of inertia of the wheel itsel?:confused:
I'm confident that you can reason the answer to this question yourself.
As a guide, consider the following example:
When you're in a grocery store and you first get the shopping cart from up front, it's fairly easy to whip that thing in and out of aisles. Very soon; however, the cart begins to become more sluggish. Eventually, after piling in countless boxes of cereal, a gallon of milk, some steak, a lobster tail, chocolate chip cookies, nutri-grain bars, icecream, and that loaf of bread, you'll be doing good to make the turn down aisle 11 without knocking over the self-checkout registers. And if some tasty-looking treat catches your eye and you stop moving, may God be with you in getting that damn thing moving again. :wink:
It sounds like friction is being ignored [as well as the mass of the cart]. In that case, you can do a straightforward F=ma calculation where acceleration is the only quantity not given.
thanks guys...it makes sense, but here is my problem:in all the physics problems i saw, dealing with rotational and translational motion, only the acceleration of one wheel being pulled by a force was discussed; are there any physics problem that deal with the acceleration of a load carried by two wheels?(a wagon,cart what have you) how would the calculation differ? thanks very much for your help
The mass of the load does matter. The wheel size, or number of wheels, does not matter [even if they are of different sizes]. All wheel surfaces accelerate at the same rate. RPM's are the only theoretical variable. In the real world [i.e., the world of engineering] the problem is more complex - mainly because friction cannot be ignored.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
