Rotational Motion and torque problem
The discussion addresses several concepts in rotational motion and torque. It clarifies that the torque of a weight about any vertical axis is not always zero, depending on the axis's position. When a sphere rolls on a horizontal surface, points on the sphere exhibit varying vertical velocities, with the center having no vertical velocity. The validity of taking the torque of resultant forces acting on different particles is confirmed if their lines of action intersect at a common point. Additionally, in pure rolling motion, angular velocity remains independent of the distance from the axis of rotation, as the angle subtended does not depend on that distance.
Alche
1)The torque of the weight of anybody about any vertical axis is 0. Is it always true?
2)A sphere rolls on a horizontal surface. Is there any point of the sphere which has a vertical velocity?
3) When several forces acts on a particle we take the torque of the resultant force. Is this result valid for the force acting on different particles of a body in such a way that their lines of action intersect at a common point ?
4)In pure rolling angular velocity is independent of the distance r from the axis of rotation. Why ?
1. Not unless the axis passes through the centre of mass.
2.yes
3.yes
4.The angle subtended doesn't depend on r & hence neither does the angular velocity.
2.yes
3.yes
Can you tell which point has vertical velocity for second question
Suppose the sphere is rolling to the left. Draw a vertical line through the centre. Every point on the sphere to the right of the line is moving upward, every point to the left is moving downward. The only points on the surface that have zero vertical velocity are the point in contact with the ground, and the point directly opposite (the highest point on the surface). Edit: My bad. I should have said, any point along the vertical line will have no vertical velocity, not just the points at the extreme ends of the line.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
