Calculate Angular Acceleration of Rotational Motion: 4.9rev in 1s
To calculate the angular acceleration of a tire that completes 4.9 revolutions in 1 second, the correct approach involves recognizing that the motion is not at constant angular velocity. The conversion from revolutions to radians yields an angular speed of 30.7876 rad/s. However, since angular velocity changes over time, the formula a = w/t is inappropriate. Instead, a kinematic equation analogous to s = (1/2)at^2 should be used to find the angular acceleration. This clarification helps in correctly solving the problem.
islanderman7
A tire placed on a balancing machine in a service station starts from rest and turns through 4.9 revolutions in 1.0 s before reaching its final angular speed. Calculate its angular acceleration.
I need my answer in
rad/s^2
a=w/t
1rev= 2n rad
Converted rev/s to rad/s
4.9rev/s * (2n rad/s)/ 1 rev= 30.7876 rad/s
a=w/t
a= (30.7876 rad/s)/ 1sec => 30.7876 rad/s^2
This answer comes out wrong.
What am I doing wrong?
It's not a constant angular velocity question. Angular velocity changes with time, so you can't just use a=w/t. You need a formula analogous to s=(1/2)*a*t^2 for linear motion. It looks very similar, just the meaning of the letters changes.
Okay thanks. I get it now.
