What Is the Rotational Temperature of 31P14N in Interstellar Space?
The discussion focuses on determining the rotational temperature of the molecule 31P14N in interstellar space, based on its microwave spectral transitions. The user has calculated the moment of inertia and obtained a value of 1.125K for the rotational temperature but is uncertain about the next steps. They are advised to apply the Boltzmann distribution to analyze the equal intensity of the second and third spectral lines. The intensity of rotational transitions is linked to the population of rotational states, which can be expressed using the provided equations. The conversation emphasizes the importance of understanding the relationship between intensity and temperature in molecular spectroscopy.
burns96
Hi there, I have a question that I'm not sure how to go about solving:
I've been given a series of transitions in the microwave spectrum of 31P14N and have assigned these Jinitial and Jfinal quantum numbers, calculated the bond length etc.
The next part says that when 31P14N is observed in the very cold environment of interstellar space by microwave spectroscopy, the second and third lines have equal intensity, and asks what the rotational temperature of the molecule in this environment would be. Any help would be greatly appreciated.
ΘR = ħ2/2kBI
ni/n0 = (2J+1) exp [-BJ(J+1)/kT]
I have 3.581 x 10-46 for I
But then plugging this into the equation I get 1.125K
I'm a bit unsure of where to go from here, I'm told I need to work out the Boltzmann distributions, is that for the two lines of equal intensity, and do I use the rotational temperature for T?
ΘR = ħ2/2kBI
The intensity (I) of a given rotational transition (J->J+1) is:
I(J) = N_J *S(J) where S is the line strength.
I(J) = const * (2J+1)exp [-B*J*(J+1)/kT]*S(J)
For a linear molecule, S(J) = mu^2 * (J+1) /(2J+1) -- Townes and Schalow, "Microwave Spectroscopy"
I(J=0)/I(J=1) = 1 = ...
Plug in and solve for T.
