Rusting of Magnesium: Equation & Experiment
  • Thread starter Thread starter tanya234
    Magnesium Rusting
The discussion revolves around the rusting process of magnesium when it is used to protect iron in a sodium hypochlorite solution. The initial inquiry seeks the chemical equation for magnesium rusting, highlighting an experiment where magnesium prevents iron from rusting. The first response provides a basic reaction involving sodium hypochlorite and water, suggesting magnesium rusts instead of iron. However, a subsequent reply critiques the initial equations, emphasizing the need for a redox reaction involving the oxidation of magnesium and the reduction of hypochlorite. The corrected equations detail the formation of magnesium hydroxide and the potential for magnesium oxide production under certain conditions. The discussion also notes the possibility of mixed products like magnesium chloride and sodium hydroxide as side products.
tanya234
Hi I was wondering what would be the equation for the rusting of magnesium?
I did an experiment where an iron nail was covered by a strip of magnesium and was put into diluted NaOCl (diluted sodium hypochlorite solution). Apparently the magnesium protects the iron from rusting and hence rusts instead.
Thanks,
Tanya
Chemistry news on Phys.org
reply from HONG KONG CHEM LOVER
1st: NaOCl+ H2O <>(reversible) NaCl + 2OH-
2nd: Mg + 2OH->MgO (rust) +H2O
is it right, i am not sure
Hello
I am not sure the equations in the first reply is totally correct, the products are okay though; hypochlorite has 1+ valence on chlorine, but chloride consists 1- valence. So there has to be a redox chemistry, and therefore, a reduction step. The electrons must have released from magnesium atom, so magnesium atom must undergo an oxidation step. Let me summarize these below:
Mg ---> Mg2+ + 2e-
NaClO + 2e- + H2O ---> NaCl + 2OH-
Mg + NaClO + H2O---> Mg(OH)2 + NaCl
But magnesium oxide may also be produced if the temperature of the medium is sufficiently high to cause dehydratation (water removal):
Mg(OH)2 ---> MgO + H2O
PS: Please note that this approach is the ideal one; you may also predict that mixed products like Mg(OH)Cl and MgCl2 are likely to occur, but with a limited probablity. Therefore, sodium hydroxide is another possible side product.
Regards
chem_tr
YES~ mine one is incorrect..
sorry, i hve overlooked the Cl in OCl is +1
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
