How Does Ryder's QFT Text Handle Complex Gaussian Integrals on Page 168?
  • Thread starter Thread starter Jimmy Snyder
    Qft
The discussion centers on a complex Gaussian integral from Ryder's text, specifically addressing an error in the definition of the parameter alpha. The integral is evaluated using equation (5A.3), but discrepancies arise due to Ryder's definition of alpha as m/(2h(t_1 - t_0)), which leads to incorrect factors in the final expression. By redefining alpha as m/(2ħ(t_1 - t_0)), the calculations align correctly, resolving the issues with the exponent and the prefactor. Additionally, a missing minus sign in equation (5.40) and an unusual choice of variable for momentum are noted as further concerns. Overall, correcting these definitions and factors clarifies the integral's evaluation.
Jimmy Snyder
I have edited Ryder's text to emphasize the issue I am having. The actual text is approx. 40% down from the top of the page.
(\frac{2\alpha}{i})^{3/2}\int exp(\frac{i}{2\hbar}\mathbf{P\cdot x} + i\alpha \mathbf{x}^2)d\mathbf{x}
The integral may be evaluated by appealing to equation (5A.3) giving
exp(\frac{i\mathbf{P}^2(t_1 - t_0)}{8m\hbar})
\alpha = \frac{m}{2h(t_1 - t_0)}
eqn (5A.3)
\int exp(-ax^2 + bx)dx = (\frac{\pi}{a})^{1/2}exp(\frac{b^2}{4a})
The integral is in the form of eqn (5A.3) where
a = -i\alpha; b = \frac{i\mathbf{P}}{2\hbar}
and there are 3 dimensions. So
= (\frac{2\alpha}{i})^{3/2}(\frac{i\pi}{\alpha})^{3/2}exp(\frac{-i\mathbf{P}^2h(t_1 - t_0)}{8m\hbar^2})
= (2\pi)^{3/2}exp(\frac{-i\mathbf{P}^22\pi(t_1 - t_0)}{8m\hbar})
so there are a couple of embarassing factors of 2\pi hanging about.
Where did you get that 2pi in the last equation from ?
Are you asking about:
(\frac{2\alpha}{i})^{3/2}(\frac{i\pi}{\alpha})^{3/2} = (2\pi)^{3/2}
or about:
\frac{h}{\hbar} = 2\pi
Never mind, the issue is an error in the book. The book defines:
\alpha = \frac{m}{2h(t_1-t_0)}
and has the following factor in the equation:
But if you define
\alpha = \frac{m}{2\hbar(t_1-t_0)}
then the correct factor is
(\frac{\alpha}{i\pi})^{3/2}
then everything works out.
I should have seen this earlier since this is the only way to justify the factor
e^{i\alpha\mathbf{x}^2}
I note another typo on the page, there is a missing minus sign in the exponent in equation (5.40). The minus sign is replaced when this equation is used in (5.42) on the next page. Also, even though it is not wrong, I find the choice of q to represent momentum in equation (5.41) to be weird.
I see, it was the second case. So you're claiming that Ryder's wrong, in the sense that his formula just b4 5.40 is wrong. Let's see. I'm getting something like
...\cdot \mbox{exp}\left(\frac{-8\pi^{2}i\left(t_{1}-t_{0}\right)}{mh}\right)
which is totally different than Ryder's or your result.
Do you have a copy of the second edition at hand?
Note that in the equation at the bottom of page 167 there is a factor of
exp(\frac{im(\mathbf{x_0 - x_1})^2}{2\hbar(t_1 - t_0)})
On page 168, about 20% down the page there is an equation in which this has been converted to:
where
and
\mathbf{x = x_0 - x_1}
This is incorrectly converted. In order to fix the problem, either the exponent must be changed, or alpha must be changed. I have followed the second course and defined:
\alpha = \frac{m}{2\hbar(t_1 - t_0)}
This fixes the exponent, but then the factor of
must become
Once these changes are made, I believe everything else falls into place.
