Calculating Hydrogen-Oxygen Ratios at the Space Center
A visit to the Huntsville Space Center prompted calculations of hydrogen-oxygen ratios for liquid hydrogen stages, revealing a theoretical mass ratio of 4:1, but actual measurements showed the second stage at 5:1. This discrepancy may stem from tank design constraints rather than fuel chemistry alone. Both stages utilized a rich fuel mixture, which enhances thrust by providing additional mass for momentum transfer. The discussion also explored the differences between running fuel-rich versus oxidizer-rich mixtures, highlighting concerns about cost, storage temperature, and reaction rates. Ultimately, a lean mixture could quench the reaction, affecting performance.
flatmaster
I went to visit the space center in my new home of Huntsville AL the other day. I figured i'd do a quick calculation from tank capacity as read from the plaque for the second and third liquid hytrogen stages. Assuming an ideal reaction, there should be a mass ratio of oxyogen to hydrogen of 4:1. This calculation comes from the straight foreward chemistry of the reaction and the respective molar masses of hydrogen and oxygen.
The third stage was close to this ratio. However, the second stage was closer to 5:1. Could a difference this big be atribuable to the engineering of a particular geometry of the tank to fit within the structure?
Also, I was sure to read the fuel masses rather than tank volumes.
The stoichiometric ratio is 8:1 (H2O=116O+21H, 16:2), not 4:1. Both the second and third stages used a very rich fuel mixture. The reason: While running rich does slows the exhaust, it does so just a little bit. You can think of it as if those extra hydrogen ions in the exhaust stream as hitching a free ride. The vehicle gets a corresponding free ride the other direction.
Ok. I see my mistake now. I understand how running fuel rich would provide extra mass for some more momentum transfer rearwards, resulting in more thrust. However, what would be the difference between running fuel rich rather than oxidizer rich? Expense of LOX? storage temperature? Reaction rate? Can I assume that the extra reaction force from a heavier oxygen would be the same as from the lighter hydrogen?
No. A lean mixture would essentially act as a quench.
A *very* old paper: http://digidoc.larc.nasa.gov/report/tn/19/NACA-TN-4219.PDF
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
