Searching for Outgassing Rate of Fused Silica (SiO2)
  • Thread starter Thread starter esorolla
    Rate
Fused silica outgassing rates are not readily available in common databases, prompting a user to seek information from the Chemical Information Sources Discussion List. A librarian provided helpful resources, including links to NASA's outgassing database and another from the University of Alberta. While the NASA site contains relevant data, some concepts like TML may not be clearly explained. The discussion highlights the importance of consulting specialized sources for specific material properties. These resources can aid others seeking similar information on outgassing rates.
esorolla
Hello everybody
I'm looking for the outgassing rate of some very common material: fused Silica. The problem is that I cannot find any database where to get the value of it. I found a table where the values of the outgassing rates for some specific glass were shown, but nothing about the simple Silica (SiO2). I saw the outgassing rates of other materials but not for the SiO2.
Does any of you know where could it be found, please? Some handbook of vacuum technology or something like this?
Thanks in advance. Regards
Chemistry news on Phys.org
Ask librarian.
And I am not joking, I am observing Chemical Information Sources Discussion List, quite often they know sources for such things, or know where to look for them.
Hi everybody
I made what I've been told and I received an answer from a librarian. Thank you Borek for your help. I attach the links that I received of a very kind librarian from my university just in case somebody else was looking for the same data:
http://outgassing.nasa.gov/
http://www.ee.uAlberta.ca/~schmaus/vacf/outgas.html
I'd say that in the NASA webpage some concepts are not well-explained but the data are there. In my opinion, TML and some other concepts are not well-explained, but you have something to start.
Have a nice day!
thank you esorella...:)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
