Second Order Differential Equations
roam
Solve the following initial value problem:
\frac{d^2y}{dt^2} + 2 \frac{dy}{dt}+y = t
y(0) = 1, \ y'(0) = 0
The correct answer must be: y(t)=3e^{-t} + 2 t e^{-t} + t -2
Where did they get the term 2te-t from?
Here's how I've done it so far:
We can find the general solution of the corresponding homogeneous system:
\frac{d^2y}{dt^2} + 2 \frac{dy}{dt}+y = 0
\frac{d^2 e^{st}}{dt^2} + 2 \frac{de^{st}}{dt}+e^{st} = (s^2 + 2s +1) e^{st} =0
(s+1)(s+1) \implies s=-1
So we have a repeated eigenvalue. Solution to the homogeneous equation is
y_h= C_1 e^{-t}
Now we must find a particular solution, I chose yp=t-2, since we it is a solution of the nonhomogeneous equation. Therefore the solution is
y = yh + yp = C1 e-t + t - 2
Now I can use the given initial values to work out C1:
y' = -C1e-t + 1
y(0) = C1 - 2 = 1 ⇒ C1 = 3
y'(0) = -C1+1 = 0
I get y = 3e-t + t - 2, but there must be another coefficient so we can solve two equations in two unknowns. But how do we get the term 2te-t? Even if I wrote the repeated eigenvalue twice C1e-t + C2e-t, I still don't get the term 2te-t. So what's the problem?
Any help is greatly appreciated.
y_h= C_1 e^{-t}
No, this is only one solution, and you need two. In cases like this where there is a repeated root of the characteristic equation, you get another solution by multiplying by t.
So two solutions of the homogeneous equation are
\{e^{-t}, te^{-t}\}
The solution to the homogeneous equation would be all linear combinations of the above; ##y_h= C_1 e^{-t} + C_2t e^{-t}##
y' = -C1e-t + 1
y'(0) = -C1+1 = 0
A better particular solution to the nonhomogeneous problem would be yp = A + Bt
Oh I see, that makes perfect sense to me know. Thank you so much for your help, I really appreciate it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
