bemigh
- 29
Hey everyone, check out this question:
Two point charges each of magnitude 2.14 µC are located on the x axis. One is at x=1.39 m, and the other is at x=-1.39 m. Determine the electric potential on the y-axis at y=0.505 m
Alright, so I am working on it, as you do, but then i realized, that the original point charges, the MAGNITUDE of the charges is given. This causes problems. Because then the direction of electric field at the point on the Y axis can have many different directions (when the charge of the original points change). For instance, if both charges are positive, the electric field at the point on the Y axis is 6007.36 N/C, however, if one of them is negative, the field is now 16535.14 N/C (when you add the sum of the vectors, etc etc...
Anyone have any insight??
Cheers
Brent
Cheers
Brent
