Self Buckling Initial conditions
The discussion focuses on the complexities of proving self-buckling, particularly the mathematical condition that arises when x=0, leading to the conclusion that A=0. The original poster struggles with understanding this aspect, suspecting a mistake related to Bessel functions. Despite the mathematical intrigue, one participant notes that self-buckling has minimal practical applications in engineering, which may contribute to the lack of responses. The conversation highlights the challenge of bridging theoretical mathematics with real-world engineering scenarios. Overall, the topic remains largely theoretical with limited practical relevance.
Vincent Isoz
Hi
For a book I'm writing, i try to write a very very very detail proof of self-buckling.
I did it almost by taking inspiration of:
https://en.wikipedia.org/wiki/Self-buckling
But i really really don't get how we arrive to, that when, x=0 as we obviously must have:
\dfrac{\mathrm{d}^2 x}{\mathrm{d}x^2}(x=0)=0
that A=0? This last point i don't get it. I must do a stupid error using Bessel functions properties but since 3 weeks I'm trying and i fail... Any help would be greatly appreciated.
Thx
While this topic is mathematically interesting, it has little practical application. In 50+ years as an engineer dealing with mechanics problems of all sorts, I have never seen anything close to this in real life, and I don't know of anyone who has. This may well be why you are not generating lots of answers.
Likes Nidum
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
