Sending InfraRed Signal to RS 232: Circuit Requirements
  • Thread starter Thread starter N468989
    Infrared
To transmit a signal over InfraRed to an RS 232 port, a circuit requires an IR photodiode, a phototransistor, and a resistor for current regulation. Components with built-in Schmitt triggers are recommended to ensure clear on/off signals. While building a custom circuit is possible, purchasing a dedicated converter is advisable for reliability and ease of use. It's important to note that not all equipment is compatible with every converter, as some may require additional connections beyond just Tx, Rx, and GND. Overall, understanding these requirements is crucial for successful signal transmission.
N468989
does anyone know how what type of circuit i need to transmit a signal over InfraRed. the signal i want to transmit is for example one byte -> 1010 1010
the byte sent will be sent to a RS 232 port
i have a shift register with the data ready to be sent
i know that i need a IR photodiode and a phototransistor
Science news on Phys.org
Welcome to PF, Tko.
I have no clue about your problem, but it might be better suited to the Electrical Engineering section.
Basically, that is ALL you need (you will also need a resistor to set the current; and a power-supply). However, make sure you get components with built in schmitt triggers (which means that the dioded will either be "on" or "off").
However, for any serious work you are better off buying a converter; they are not very expensive.
Also, note that not all types of equipment work with all converters. They are basically equivalent to a null-modem with only Tx, Rx and GND connected; some equipment requires more connections.
