Sensor in car to calculate weight distribution?
The discussion centers on finding an effective method to measure weight distribution across a car's tires in real-time. Adrian considers using strain gauges or displacement sensors but doubts their accuracy, leaning towards a 6-axis accelerometer at the vehicle's center of mass. Other participants suggest that modern ABS systems can infer weight distribution through wheel slip data, while some propose using force sensors between shocks or measuring spring compression for better accuracy. Adrian plans to use velocity data from the ECU, a potentiometer for braking force, and a steering sensor to calculate a variable for a dynamic spoiler, emphasizing that extreme accuracy is not necessary for their application. The conversation highlights the challenges of accurately measuring vehicle dynamics and the importance of integrating multiple sensor types for improved results.
aortucre
Hello,
I’m currently working on a project in which I need to know the weight distribution in the four tires of a car at all times. I was thinking to install strain gauges somewhere in the chassis, or displacement sensors by the suspension. However I don’t feel these methods will give me accurate results. The other option was to install an accelerometer at the center of mass of the vehicle that would tell me how much it inclines when braking and cornering.
Please tell me your thoughts on this. Any help is good!
Thanks in advance
Adrian
i tried that about 20 years ago. Used a long stroke by directional cylinder and a liquid filled pressure gage. Mounted it on the right front of the race car and placed a huge cam corder ( that's all we had back then) so it could record the pressure and where it was relative to the race track...worked half way good but this was before we knew about roll centers , Center of Gravity, mass centroid, polar moments and all the stuff that we should have looked at first before trying to bandaie an ill handling car...
today i think you can hang some cheap displacement sensors on t he suspension and plumb the data into some type of dat collector and really skull out what's happening..
anyway..welcome and good luck
Are you talking about measuring it directly, or being able to calculate it from other sensors?
Anything to do with the motion of the body will be horribly inaccurate. You'd need to know far too much design detail about the car to make it work.
Modern ABS 'knows weight distribution' when the brakes are applied by measuring wheel slip against applied braking force. Not sure how you would do it at all times though...
Ranger Mike and Kozy. Thank you for your answers.
I was thinking that installing a 6 axis accelerometer in the center of mass of the car might not give accurate results. The other option was to install three sensors that would give me the velocity, steering and braking force:
-Velocity: Pitot tube
-Steering: Turning sensor in the steering column (+account for power steering)
-Braking force: Potentiometer installed in the axis of rotation of the brake pedal and map such analog signal to a set of empirical data for braking force.
The other option was to use the information from the engines traction control and knowing the coefficient of friction with the ground use that information to calculate the force on each tire. (This is similar to what Kozy is saying). However you will only get information when there is slippage.
If you have any other ideas please let me know! Thanks again
Something about your velocity/ steering/ braking force seems like it would be horribly inaccurate. A pitot tube would be affected by wind speed (maybe better to get velocity off the wheels...but even that is inaccurate). Steering and braking force...those are all sensing the inputs. Braking force can and will change depending on conditions, such as wear, weather, and especially heat. Steering just the same...it will vary depending on many conditions.
I would guess accelerometers and/ or a gps would be better suited for calculating speed/ braking/ acceleration. But even then you would have to accurately know many car parameters, which would be subject to change. Everything would be thrown off depending on how much fuel you have or what you had for lunch.
The most accurate way would probably be to somehow place force sensors between each shock and mount. I don't know how difficult that would be though.
Or maybe figure out the spring constants at each corner, and install a sensor to measure the spring compressions?
Lsos first of all thanks for your input.
The results don’t have to be extremely accurate. Remember that we are going to use them to drive a dynamic spoiler that can only move within a certain range. What we are trying to do is use the three parameters described before (velocity, braking force and steering angle) to calculate a variable X. This variable can be either positive or negative, depending on whether the driver is steering to the right or left, and it will be mapped to an array of data that will represent the displacement of the actuators. (from 0” to 12” or 18”). Also the actuators will update their positions around 10 times per second.
The velocity we have decided to obtain from the ECU, the braking force will be calculated placing a rotating potentiometer by the braking pedal, and the steering will be calculated by either a rotating potentiometer around the steering column or an accelerometer on the mass center of the car.
Thanks again to everyone for their inputs and let me know what you think of this update.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
