Series Connected D.C Motor Characteristics
  • Thread starter Thread starter 1988ajk
    Motor Series
A series connected D.C. motor exhibits a hyperbolic torque-speed relationship rather than a linear one, with speed decreasing as torque increases. The motor provides excellent starting torque due to the low resistance of the series field winding, which saturates quickly. However, as armature current increases from no load to full load, the torque diminishes. This behavior contrasts with permanent magnet motors, which are presumed to have similar characteristics since the magnets perform a comparable function to windings. Overall, series D.C. motors excel in starting torque but struggle with speed regulation under varying loads.
1988ajk
Hi all,
Please excuse me for such a simple question, I am a predominantly a mechanical engineer.
Does a series connected D.C Motor have a linear speed/torque relationship or a curve?
I am aware that both have speed (RPM) decreasing as torque (Nm) increases.
Many thanks in advance!
Many thanks,
the last post has cleared up some ambiguous notes I have.
Since your series field is in series with your armature, and has a very low resistance, about .4 ohms... it saturates very quickly providing maximum flux on relatively low provided current. For that reason, the motor has Amazing starting torque, but since the winding is saturated early it produces less and less torque as armature current is applied form no load to full load.
In summary, the motor has excellent torque on starting, but has poor speed regulation from no load to full load (as armature current is applied)
say if the d.c motor were a permanent magnet type, would this have the same characteristics?
I presume that they would stay the same, as the magnets do the same 'job' as windings.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
