Convergence Test for Series with Exponential and Polynomial Terms
wanchosen
I am having problems with the following question:
Using an appropriate convergence test, find the values of x \in R for which the following series is convergent:
(\sumnk=1 1/ekkx)n
I used the ratio test to solve this but I'm not so sure about my solution:
n1 = \frac{1}{e}
n2 = \frac{1}{e} + \frac{1}{e^2 * 2^x}
n3 = \frac{1}{e} + \frac{1}{e^2 * 2^x} + \frac{1}{e^3 * 3^x}
n4 = \frac{1}{e} + \frac{1}{e^2 * 2^x} + \frac{1}{e^3 * 3^x} + \frac{1}{e^4 * 4^x}
\sum all n = \frac{n}{e} + \frac{n-1}{e^2*2^x} + \frac{n-2}{e^3*3^x}
So,
Un = \sumnn=1 \frac{n-(k-1)}{e^k*k^x} = \frac{n-(k-1)}{e^n*n^x}
Un+1 = \sumnk=1 \frac{(n+1)-(k-1)}{e^n*n^x} = \frac{n-k+2}{e^(n+1) * (n+1)^x}
n-->\infty
Un+1/Un = \frac{(n-k+2)n^x}{(n-k+1)*(n+1)^x}
divide by n
= \frac{((1-(k/n))n^(x-1)}{(1-(k/n)+(1/n)*((n+1)^x)/n}
Lim\infty nx-1 if convergent
|nx-1| < 1
so,
x-1 < 0
x < 1
Does this look right?
How did you get this?
\sum all n = \frac{n}{e} + \frac{n - 1}{e^2 * 2^x} + \frac{n - 2}{e^3 * 3^x}
I assumed because the whole expression is encased in ()n that we summed all terms for each value of k upto n.
I'm not sure why you are calling the "n1", "n2", etc. I presume you just mean "n= 1", "n= 2", etc.
And, I'm not at all clear on what you are doing calculating all those terms. You said you used the ratio test but that's just
\left(e^{-k}k^{-x}\right)\left(e^{k+1}(k+1)^{x}\right)= e\left(\frac{k+1}{k}\right)^k
What is that as k goes to infinity? For what x is it less than 1?
Yes, I had misunderstood the ()n.
I believe, effectively the series is :-
\sumn \frac{1}{e^n * n^x}
If
Un = \frac{1}{e^n * n^x}
and
U(n+1) = \frac{1}{e^(n+1) * (n+1)^x}
then
U(n+1)/Un = \frac{n^x}{e * (n+1)^x}
Therefore if the series is convergent:
\frac{n^x}{(n+1)^x} < e
ln(\frac{n^x}{(n+1)^x}) < 1
x * ln(\frac{n}{n+1}) < 1
n/n+1 is always positive but less than one :- ln term is negative,
x > \frac{1}{ln(n) - ln (n+1)}
but is this a final solution?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
