Solve for (a-1) using a series - Logic Problem Solution
  • Thread starter Thread starter Bounceback
    Proof Series
Bounceback
iiii(a-1)!iiiiiiiiiiiiii(a-1)!iiiiiiiiiiiii(a-1)!iiiiiiiiiiiiiiiiii(a-1)!
------------ii+ii------------ii+ii------------iiiiiii+ii------------ii=ii2a-1
i(a-1)!*0!iiiiiiiiii(a-2)!*1!iiiiiiiii(a-3)!*2!iiii...iiiiiii0!*(a-1)!
In case you are having trouble reading that:
(a-1)!/((a-1!*0!)) + (a-1)!/((a-2)!*1!) + (a-1)!/((a-3)!*2!)... + (a-1)!/(0!*(a-1)!) = 2<sup>a-1</sup>
Assuming a = positive integer
Essentially, I haven't had much experience with logs, and would be interested in a hint to making this a little more workable.
The next part incorporates part of a logic problem. If you haven't completed (click here), don't continue
Each term represents a number of combinations that occurs with a specific number of objects. For example, if you have 10 people and want to find out how many combinations there are of them going to a party (1,6,10), (1,3,5,9,10) etc; you can find out by finding how many different combinations of 1 person there are, how many combinations of two people, etc. Essentially, I developed a chart to represent it:
1 1 1 1
1 2 3 4
1 3 6 10
1 4 10 20
And a formula to find any term where x=row # and y=column #
iii(x+y-2)!
(x-1)!*(y-1)!
The series above represents a sum of the diagonal of the chart. Someone else also noticed that the same problem could be solved using binary, hence the fact that they equal each other.
I can go into more detail about how I developed this if requested
2^{a-1}=(1 + 1)^{a-1} =1^{a-1}+\frac{a-1}{1}1^{a-2}1^{1}+...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
