Set theory homework - Theoretic reasoning
7 replies · 2K views
loplol
Prove where X and Y are both sets use theoretic reasoning
i) Z \ (X [itex]\cap[/itex] Y) = (Z \ X) [itex]\cup[/itex] (Z \ Y)
ii)(Y \ X) [itex]\cup[/itex] Z = (Y [itex]\cup[/itex] Z) \ (X \ Z)
iii) Z \ (Y \ X) = (X [itex]\cap[/itex]Z) [itex]\cup[/itex](Z \ Y)
\ = set difference
i know you don't do other peoples work for them but i am very clueless on this subject a guiding hand with step by step help would be greatly appreciated
If you mean just regular "proofs", each of those is basically to prove "A= B" where A and B are sets. And the standard way to do that is to prove "[itex]A\subset B[/itex]" and then "[itex]B\subset A[/itex]". Finally, the way to prove [itex]A\subset B[/itex] is to start by saying "let x be a member of A" and prove, using the definitions of A and B, that x must be a member of B.
For example, you want to prove, in (i), that
[tex]Z\(A\cap B)= (Z\A)\cup (Z\B)[/tex]
so you start by proving
[tex]Z\(A\cap B)\subset (Z\A)\cup (Z\B)[/tex]
And you do that by saying "let x be in [itex]Z\(A\cap B)[/itex]" which means, of course, that x is in Z but not in [itex]A\cap B[/itex]. Saying that x is not in [itex]A\cap B[/itex] means x is not in both A and B. So there are two possibilities- x is in Z and A but not in b or x is in Z and B but not in A. Do those two possibilities as two cases:
1) x is in Z and A but not in B. Then, since x is in Z but not in B, x is in Z/B. Do you see why that means x must be in [itex](Z/A)\cup(Z/B)[/itex]?
2) x is in Z and B but not in A. Then, since x is in Z but not in A, ...
ok i understand 1)
heres my attempt at 2)
(Y \ X) ∪ Z = (Y ∪ Z) \ (X \ Z)
let x be in (Y \ X) ∪ Z
-x is in Y and Z but not in X, so x is in X\Z
also (Y ∪ Z) \ X, because x is in Y and Z but not in X
hence (Y \ X) ∪ Z = (Y ∪ Z) \ (X \ Z)
THIS OK?
No, but it is a start. That shows that
[tex](Y\X)\cup Z\subset (Y\cup Z)\(X\Z)[/tex]
You still need to show the other way.
what do you mean when you say show the other way?
is the 'other way' this?
-x is in X and Z but not in Y, so x is in Y\Z
so overall
A = B if and only if A ⊂ B and B ⊂ A.
You showed that (Y \ X) ∪ Z ⊂ (Y ∪ Z) \ (X \ Z). You still need to show that (Y ∪ Z) \ (X \ Z) ⊂ (Y \ X) ∪ Z.
ok lol kinda obvious isn't it
ok here's a revised version of 2
-x is in Y and Z but not in X, so (Y ∪ Z) \ X
let x be in (Y ∪ Z) \ (X \ Z)
-x is in Y and Z, so x is in Y∪Z
-x is in Z but not in X, so x is in A\C
-x is in Y and Z but not in X, so x is in (Y∪Z)\X
good?
