Solving Integrals: x/√(1-x)
  • Thread starter noblerare
  • Tags
    Integrals
C is a constant of integration. In summary, the problem involved solving the integral \int\frac{xdx}{\sqrt{1-x}} using different methods such as the conjugate and u-substitution. However, neither method was successful. The solution was found by using the substitution u=1-x and splitting the integral into two parts. The final solution is \frac{2}{3}u^{3/2} - 2\sqrt{1/(1-x)} + C, where C is a constant of integration.
noblerare
50
[SOLVED] Several Integrals
[tex]\int[/tex][tex]\frac{xdx}{\sqrt{1-x}}[/tex]
n/a
I tried to multiple top and bottom by the conjugate:
[tex]\int[/tex][tex]\frac{x\sqrt{1+x}dx}{\sqrt{1-x^{2}}}[/tex]
After trig substitution, I end up with:
-[tex]\int[/tex]cos[tex]\theta[/tex][tex]\sqrt{1+cos\theta}[/tex]d[tex]\theta[/tex]
I've also tried u-substitution but nothing seems to work.
Can anyone help me out on this? And show steps, please? Thanks so much!
Solution: We can use the substitution u=1-x, which yields\int \frac{(1-u)du}{\sqrt{u}} = \int \frac{u-1}{\sqrt{u}}duNow, we can split up the integral into two integrals\int u^{1/2}du - \int \frac{1}{\sqrt{u}}duThe first integral is easy to solve. We have\frac{2}{3}u^{3/2} + C_1For the second integral, we use the substitution v=1/u, which yields-2\sqrt{v} + C_2Substituting back for v and u respectively yields-2\sqrt{1/u} + C_2 = -2\sqrt{1/(1-x)} + C_2Our final solution is thus\frac{2}{3}u^{3/2} - 2\sqrt{1/(1-x)} + C
1. What is an integral?
An integral is a mathematical concept that represents the area under a curve in a graph. It is used to find the total value of a function over a given interval. In other words, it is the opposite operation of differentiation.
2. How do you solve integrals?
To solve an integral, you need to use techniques such as substitution, integration by parts, or partial fractions. You also need to have a good understanding of algebra, trigonometry, and calculus.
3. What is the specific technique for solving x/√(1-x)?
The specific technique for solving x/√(1-x) is substitution. Let u = 1-x, then du = -dx. This will allow you to rewrite the integral as -∫du/√u, which can be solved using the power rule for integrals.
4. Can x/√(1-x) be solved without using substitution?
No, x/√(1-x) cannot be solved without using substitution. This is because the integral involves a function within a function, making it a composite function. Substitution is necessary to simplify the integral and make it solvable.
5. Are there any applications of solving x/√(1-x)?
Yes, x/√(1-x) has applications in physics, particularly in calculating the work done by a variable force. It can also be used in probability and statistics to calculate the area under a normal distribution curve.
