Why & How do Electrons Behave in Crystaline Structures?
  • Thread starter zrs_12
In summary: What coordinate systems are used for the space and time coordinates of the Schrodinger equation?The basic issue with electrons in lattices is that the usual translational symmetry of space is broken.You cannot translate (or rotate) by any arbitrary amount, but only by a lattice vector. This basic fact is formally called Bloch's theorem, which gives a constraint on the form of the wavefunction for an electron in a periodic potential. How electrons "behave" is not a particularly well-posed problem. Like any quantum particle, trying to visualise their behavior as a billiard ball bouncing back and forth is going to run into problems.
zrs_12
*Why are electrons confined to bands where they can posses a partial quantum of energy (right?) as opposed to descrete energy levels in quantum dots?
*Why do electrons behave differently in crystaline structures?
*How do electrons behave in crystaline structure? (like bouncing back and forth) and why?
*How and why are the energy levels changed when spatial restriction occurs?
*Why does spatial restriction occur?
*What coordinate systems are used for the space and time coordinates of the Schrodinger equation?
The basic issue with electrons in lattices is that the usual translational symmetry of space is broken. You cannot translate (or rotate) by any arbitrary amount, but only by a lattice vector. This basic fact is formally called Bloch's theorem, which gives a constraint on the form of the wavefunction for an electron in a periodic potential. How electrons "behave" is not a particularly well-posed problem. Like any quantum particle, trying to visualise their behaviour as a billiard ball bouncing back and forth is going to run into problems. The bands come from the fact that you have a macroscopic (so effectively infinite) single electron states with the same energy --- one from each atom --- which mix together to produce a macroscopic number of multi-electron states, each slightly differing in energy. Thus you get a continuum of energies, occasionally separated by finite energy gaps.
Hope that's not too confusing.
Not right.
Why should they behave the same way is 2 different environments?
Deifferently from what?
Read genneth's post. The so-called behavior is encoded in the electron wavefunction. You need to learn how the wavefunction of an electron in a crystal lattice is figured, from Bloch's theorem to nearly free electron approximations to the tight binding model (to the mott-hubbard model).
Hand waving answer: spatial restriction affects the momenta through the Uncertainty relation. Alternatively, spatial restriction affects the wave vector of bound states, which in turn affects the energy through the dispersion.
Because you put in a confining potential barrier.
You choose a co-ordinate system depending on the geometry of the physical system; e.g., for a cubical quantum dot, you will use Cartesian co-ordinates.
According to Wikipedia:
When a large number of atoms (of order [TEX]10^20[/TEX] or more) are brought together to form a solid, the number of orbitals becomes exceedingly large, and the difference in energy between them becomes very small, so the levels may be considered to form continuous bands of energy rather than the discrete energy levels of the atoms in isolation.
So why do bands occur in quantum dots containing a hundred to a few thousand atoms?
The key is the symmetry. In quantum dots you arrange the structure such that you don't have a regular lattice. There's also the issue of temperature...
1. Why do electrons behave differently in crystaline structures compared to free electrons?
The behavior of electrons in crystaline structures is influenced by their surroundings and the presence of other atoms in the crystal lattice. This leads to changes in their energy levels and behavior, resulting in different properties compared to free electrons.
2. How do electrons behave in a crystaline structure?
Electrons in a crystaline structure exhibit wave-like behavior and occupy specific energy levels called bands. These bands are separated by gaps called band gaps, and the electrons occupy the lowest available energy levels.
3. Why do some materials conduct electricity while others do not?
The ability of a material to conduct electricity is determined by its band structure. Materials with partially filled bands or small band gaps between them allow for the movement of electrons, making them good conductors. Materials with fully occupied bands or large band gaps are insulators.
4. How does the arrangement of atoms in a crystal influence electron behavior?
The arrangement of atoms in a crystal affects the energy levels and band structure of the electrons. In a regular and symmetrical crystal lattice, the electrons have more distinct energy levels and are less likely to scatter or interact with other electrons, resulting in higher conductance.
5. What is the role of temperature in electron behavior in crystaline structures?
Temperature influences electron behavior by affecting the energy levels and band gaps in a crystal. At higher temperatures, some electrons may gain enough energy to move to a higher band, increasing the material's conductivity. However, at extremely high temperatures, the material may become an insulator due to the disruption of the crystal lattice.
  • Atomic and Condensed Matter
  • Quantum Physics
