Is the Shear Flow Direction Incorrect in Preventing Beam Twisting?
The discussion centers on the relationship between shear flow and beam twisting, questioning whether the direction of shear flow is correct. It highlights that both the moment due to the applied force (Pe) and the moment due to shear flow are counterclockwise, raising concerns about how Pe can prevent twisting. The conversation suggests that the shear flow might need to be directed from the bottom to the top to effectively counteract twisting. Participants clarify that Pe represents the applied force while F is the resultant force of shear flow. Understanding these dynamics is crucial for minimizing beam twist in structural applications.
fonseh
In the figure , we can notice that the moment due to Pe is counterclokwise , but moment due to shear flow is also counterclockwise , How can the Pe prevent the twisting of the beam ?
Or is the direction of the shear flow wrong ? Should it flow from the below to the top ?
From how I read it: ##P\times e## is the resultant of the shear flow and gives you a distance ##e##, the distance (on the other side of the web!) at which you can apply the actual load that offsets ##P\times e##, thus causing a minimum of twist.
Likes fonseh
why ? P is the applied force , and F is the resultant force of shear flow, right ?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
