Shell Method Example: Finding Volume Using Shell Method
  • Thread starter Thread starter Complexity
    Method Shell
Complexity
The area between the y-axis and the line y = x + 1 from y = 2 to
y = 4 is rotated about the x-axis. Use the shell method to find the
area of the resulting solid.
V = 2pi integral (radius)(height of shell) dx or dy
Well I am kind of confused with this problem, it says to find the AREA but isn't the shell method suppose to find the VOLUME?
Here is my attempt:
y= x+1 -----> x=y-1
V = 2pi integral from 2 to 4 y(y-1) dy
I then evaluated it to get = (76/3)pi as the volume.
What did I do wrong?
I'll agree with what you've done so far. The volume is 76*pi/3. If they really do want area I'd add up the area of the parts of the boundary. You've got two cylinders, a disk with a hole in it and a part of a cone. It seems like it shouldn't be too hard, but I don't know what that has to do with the 'shell method'.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
