jonmtkisco
- 532
- 1
The Newtonian Shell Theorem makes important predictions about the gravitational force experienced by an object located inside a spherically symetrical massive structure, such as a hollow or solid ball. The same predictions are made by Gauss' Law. According to http://en.wikipedia.org/wiki/Shell_theorem" :
1. If the body is a spherically symmetric shell (i.e. a hollow ball), no gravitational force is exerted by the shell on any object inside, regardless of the object's location within the shell.
2. Inside a solid sphere of constant density the gravitational force varies linearly with distance from the center, becoming zero at the center of mass.
It bears emphasizing that the Shell Theorem applies only with respect to mass arrangements which are (a) actually centered on the center of the sphere, (b) are symetrically distributed around that center, and (c) have constant density in the non-hollow portion. In this thread I want to discuss some examples that don't seem to meet all three criteria, although the issue can become interestingly subtle.
The most obvious example is that a solid or hollow shell of matter cannot act as a "gravity shield" to avoid the gravity of other nearby objects. For example a dense sphere buried just under the Earth's surface is not shielded from the Earth's gravity to any significant degree. This is so of course because the Earth is not arranged spherically around the sphere, and the center of the sphere is not the "true" center of the earth-sphere system. I attached a simple diagram which illustrates this example.
I'll post a more interesting example later.
Jon
Jon
