SHM - Equation for Displacement
  • Thread starter Thread starter Peter G.
    Displacement Shm
The discussion focuses on the equation for displacement in Simple Harmonic Motion (SHM), specifically x = x0 cos(ω * t). Participants clarify that it's acceptable to rename variables, such as changing "x" to "y," as long as it doesn't cause confusion. The term (ω * t) is explained as determining the position of the oscillator at any given time, with ω representing the angular frequency. This multiplication is necessary to convert time into an angle for the cosine function, which describes the oscillation. Understanding these components is crucial for accurately interpreting the motion of the oscillator.
Peter G.
Hi,
I just learned my first equation today in SHM:
x = xo cos (ω * t)​
Firstly, is it ok if I change the "x =" part for a "y="? I get a bit confused since, from what I understand, we want to find the vertical distance from the x-axis and that would be the y output of a function. (x makes me think of the input)
I understand the first x, representing the displacement - stretching the graph parallel to the y axis.
Now, the (ω * t) part is what confuses me. Those values will determine where in the curve we want to find the displacement, correct? If so, how do the ω and time represent which part in the curve we are looking for, like the angles we input in our calculators do?
I hope I conveyed my doubts in a clear enough way,
Thanks,
Peter G.
My proble
Sure. You can call your variables whatever you want, as long as you don't confuse yourself or the teacher.
I don't understand what you mean by "where in the curve we want to find the displacement". The equation tells you the position of the oscillator for any given moment of time. So if I had an oscillator and I wanted to know where it's going to be at 10 seconds, I would calculate x0*cos(ω*10 s), and that would give me the answer.
Yes, what you mentioned is what I meant. Now, what role does ω have? Why do we have to multiply it by time to get the position in the cos curve, as we usually do by inputting angles in degrees or radians?
