The Golden Ratio and Cosine: A Surprising Relationship
  • Thread starter PcumP_Ravenclaw
In summary, the conversation discusses how to show that cos(π/5) is equal to the Golden Ratio by using De Moivre's theorem and a polynomial of degree five. It is stated that P(cos θ) = 0 for some polynomial P, and it is observed that P(z) can be factored into (1-z)Q(z)^2 for some quadratic polynomial Q. It is clarified that from P(z) = 0, there are 5 solutions, but from P(cos θ) = 0, θ does not need to be zero and cos(θ) does not need to be zero.
PcumP_Ravenclaw
106
Show that cos(π/5) = λ/2, where λ = (1 +√5)/2 (the Golden Ratio).
[Hint: As cos 5θ = 1, where θ = 2π/5, we see from De Moivre’s theorem
that P(cos θ) = 0 for some polynomial P of degree five. Now observe that
P(z) = (1 − z)Q(z)2 for some quadratic polynomial Q.]
Not sure how!
from P(cos θ) = 0
there are 5 solutions for p(z) and one solution for θ. but then only one of the 6 multiplying factors needs to be zero right?
i.e. ## (z - a)(z - b)(z - c)(z - d)(z - e)(Cos θ) = 0 ## only one of them needs to be zero because anything multiplied zero is also zero.
Is the last factor supposed to be Q(z)2?
Not sure how!
from P(cos θ) = 0
No. From P(z) = 0, there are 5 solutions, but from P(cos θ) = 0, θ doesn't need to be zero and cos(θ) doesn't need to be zero.
1. What does "cos" stand for in this equation?
"Cos" stands for cosine, which is a mathematical function that relates the ratio of the adjacent side to the hypotenuse of a right triangle.
2. How do you calculate π/5?
π/5 is equal to 36 degrees or 0.628 radians. It can be calculated by dividing the value of π (3.14) by 5.
3. What is the value of λ in this equation?
λ represents the wavelength, which is a measurement of the distance between two consecutive points on a wave. In this equation, it represents the value of the adjacent side of a right triangle.
4. How do you prove that cos(π/5) equals λ/2?
To prove this equation, we can use the cosine formula: cos θ = adjacent/hypotenuse. By substituting the known values of θ (π/5) and the adjacent side (λ), we can solve for the value of the hypotenuse (2). This shows that cos(π/5) = λ/2.
5. What is the significance of this equation in mathematics?
This equation is significant because it shows the relationship between the cosine function and the wavelength in a right triangle. It also demonstrates the use of trigonometric functions in solving real-world problems, such as calculating the length of a side in a right triangle.
