Proving the Maximum of a Cubic Polynomial: Solving for Cases of Equality
  • Thread starter Thread starter .d9n.
.d9n.
Let f(x) = x^3+ ax^2+ bx + c with a, b, c real. Show that
M = max|f(x)|≥1/4
-1 ≤ x ≤ 1
and find all cases where equality occurs.
|(-1 ≤ x^3 ≤ 1)+(-a ≤ ax^2 ≤ a)+(-b ≤ bx ≤ b)+c|≥1/4?
not sure how to prove without knowing what a,b,c are?
M = max|f(x)|≥1/4
-1 ≤ x ≤ 1
Adding inequalities (which are either true or false) doesn't make any sense.
Basically, what you need to show is that the largest value of |f(x)| on the interval -1 <= x <= 1, is at least 1/4.
Wouldn't the derivative be useful here?
thanks
so i have
f '(x)=3x^2 + 2ax + b
f ' (x) =0 to find critical values
= -1/3a ± (√(4a^2 -12b))/6
not entirely sure where to go from here
.d9n. said:
thanks
so i have
1. When you start a line with =, you are saying that what is just above equals what's to the right of the = sign. In this case, you are saying that
0 = -1/3a ± (√(4a^2 -12b))/6
This is not true.
When you solved using the quadratic formula, what did you solve for?
2. There is an error what you did with the quadratic formula.
sorry i meant x= (-2a±√(4a^2-12b))/6,
not sure where I have gone wrong with the formula though (-b±√(b^2-4ac))/2a, correct?
although I am not too sure how this helps me
im not meant to do this:
(-1/3a ± (√(4a^2 -12b))/6)^3+ a(-1/3a ± (√(4a^2 -12b))/6)^2 +b(-1/3a ± (√(4a^2 -12b))/6)+c
surly?
That's better.
So what are the conditions for which f'(x) = 0? Will there be no such x-values, 1 such x-value, or 2 separate x-values?
No
.d9n. said:
surly?
surly and surely are different words. Unless I miss my guess, you meant "surely."
yes i meant surely, sorry.
there will be two x values, assuming a,b≠0 i think
im unsure of how to work out what these x values are when we don't know what a and b are.
Is the second derivative useful once we have found out what the x values are to find the max
f''(x)=6x+2a
No, not true. If a = b = 2, there are no values for which f'(x) = 0.
Like I asked before, what are the conditions for which f'(x) = 0? For what values of a and be will there be no critical points, 1 critical point, or 2 separate critical points?
The Quadratic Formula gives you more information than you are using.
Also, all you are given is that a and b are real. You can't assume they aren't zero.
The issue is not *just* whether there are two critical values of x, but whether or not these two values lie between -1 and +1. On the interval [-1,1], you may have: (i) no stationary point in (-1,1)(so the max/min occur at an endpoint x = +- 1); (ii) one stationary point in (-,1,1) and the other outside it (so the min occurs in (-1,1) and the max at +- 1, or vice-versa); (iii) two stationary points in (-1,1) (so that the max may occur in (-1,1) or at an endpoint, and similarly for the min.) Somehow you need to straighten out these possibilities.
RGV
the conditions are that the function has a maximum at x=n if f'(n)=0 and f''(0) is negative
it won't have any critical points when
-2a + √(4a^2 -12b)=0 so when a,b=0
it will have two critical point when
-2a - √(4a^2 -12b)=0 → b=2/3a^2 and a=√(3b/2)?
how am i meant to work out if the critical values lie in between -1 and 1, without know what a and b are. Sorry it all getting quite confusing
Not quite, but you're getting warmer. There won't be any critical points when the discriminant < 0. When will there be one critical point? Two distinct critical points?
And as Ray pointed out, it makes a difference whether these points are in (-1, 1) or not.
if the discriminant is > 0, the polynomial has two real roots, if the discriminant is = 0, the polynomial has one real root, and if the discriminant is < 0, the polynomial has no real roots
so therefore
if 4a^2-12b>0 it has two real roots so 0<4a^2-12b<=1,
if 4a^2-12b=0 it has one real root so 4a^2-12b=0
if 4a^2-12b<0 it has no real roots so -1<=4a^2-12b<0
is this what you mean?
when you say it makes a difference whether or not the points are in (-1,1) is this because its stated that x has to be in these points in the qu?
or is it something i have missed?
also what am i meant to do now, am i meant to solve for a and b?
so therefore
Yes and no, but mostly no.
What has two real roots? Be specific. Don't use the word "it".
Why do you think that 4a2 - 12b <= 1? Where did that come from?
if 4a^2-12b=0, then of course if 4a^2-12b=0.
Again, what has one real root?
Why do you think that 4a2 - 12b >= -1?
when i say it i mean the derivative of f'(x) or should i be working out the discriminant of f(x), i.e. b^2 c^2-4ac^3-4b^3d-27a^2d^2+18abcd
so in our case would be
a^2b^2-4b^3-4a^3-27c^2+18abc,
and i realize what wrong with the <=1 and >=1, i was thinking about x.
so therefore it woudl mean the polynomial
.d9n. said:
so therefore it would mean the polynomial
Which polynomial?
There are two critical numbers (in addition to where f '(x)=0) for the interval [-1, 1].
They correspond to the end points of the interval. They are especially important if f '(x) has no roots on the interval [-1, 1] .
No offense, but this problem seems way beyond your abilities. The idea of the discriminant in a quadratic equation does not extend to cubic polynomials, which is what f(x) is. I think that your best strategy might be to sit down with your instructor.
