Showing a general solution for a wave on a string fixed at one end
catpants
http://img811.imageshack.us/img811/1989/problem1.png
All shown in the above link, AFAIK
Not worried about part a.
For part b, when they say "assume the string is initially at rest" I took that to mean:
\frac{\delta\Psi(x,0)}{\delta t}=0
But I don't know if that is right. It would be used as some sort of initial conditions for solving some diff eq. But I don't understand what that diff eq would be, or how to set it up. I would imagine I solve this diff eq using sep of vars?
The wave equation, which I presume you have already seen, since it is not mentioned in the problem is
\frac{\partial^2 \psi}{\partial x^2}= \frac{1}{c^2}\frac{\partial^2\psi}{\partial t^2}.
Yes, an initial condition is
\frac{\partial \psi(x, 0)}{\partial t}= 0[/math]<br /> <br /> (By the way, use &quot;\partial&quot; to get the \partial in LaTex.)
I think the wave equation is what I was missing. Do I try and solve it using separation of variables? Also, the end of your post got mangled, what were you trying to say?
Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
