Showing the expectation values of a system are real quantities
The discussion revolves around demonstrating that the expectation values of position and momentum in a one-dimensional quantum system are real quantities. For the position expectation value ⟨x⟩, the participant initially assumed a wave function but was advised that a specific wave function is not necessary for the proof. The focus shifted to using integration by parts to show that the momentum expectation value ⟨p⟩ is also real, with the hint provided to derive ⟨p⟩ as the complex conjugate of itself. The participant expressed confusion regarding the wave function and integration techniques, indicating a need for clarification on the approach to solving the problem. Ultimately, the conversation emphasizes the importance of using the correct wave function and integration methods to establish the reality of expectation values.
FisiksIdiot
A one-dimension system is in a state described by the normalisable wave function Ψ(x,t) i.e. Ψ → 0 for x → ±∞.
(a) Show that the expectation value of the position ⟨x⟩ is a real quantity. [1]
(b) Show that the expectation value of the momentum in the x-direction ⟨p⟩ is a real quantity, too. Hint: using integration by parts and normalisability show that ⟨pˆx⟩ = ⟨p⟩∗. [4]
1=N∫ψ*ψ.dx
<x>=∫ψ* xψ.dx over all space
<p>=∫ψ* -ih dψ/dx.dx over all space
The difficult aspect of this for me is determining what the correct wave function is. Using the information given I assumed that the correct wave function was e-ax2/2 eiEt/h (where a/2 is an arbitrary constant) as it fits the above requirements (I could be wrong.)
However, upon normalising and calculating <x> and <p>, the values obtained will of course will be 0 and therefore real as my assumption was a symmetric wave function. This is all well and good, however the question explicitly states to use integration by parts to solve for <p>.
<p>=N∫(e-ax2/2 eiEt/h) -ih d/dx(e-ax2/2 e-iEt/h).dx over all space
which gave:
<p>=N iha∫xe-ax2.dx over all space
which cannot be integrated by parts as far as I understand-perhaps it can?. Have I got the wrong end of the stick somewhere in my thinking?
Thanks in advance.
You wave function is incorrect. Do not plug it in until you have done the math. You do not even need a "test" wavefunction for part a.
Thanks for the prompt reply, but I don't quite follow. Could you clarify what you mean by 'not needing a wave function'? I feel I am approaching the problem from the wrong angle.
Hmm, perhaps forget what I mentioned previously. You simply need to reconsider your wave function. Perhaps try something of the form \psi = e^{\pm i(kx-E t/ \hbar)}. . .
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
