Showing the force on a magnetic dipole
The discussion revolves around the force on a magnetic dipole in a magnetic field, specifically in the context of a circuit that can move under the influence of magnetic forces. Participants are exploring the relationship between the magnetic dipole moment and the magnetic field, as well as the implications of various equations related to this scenario.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss starting points for deriving the force on a magnetic dipole, referencing specific equations and identities. There is a focus on the implications of the magnetic dipole moment being constant and the conditions under which certain equations apply. Questions arise regarding the applicability of these equations to different circuit configurations and the nature of the magnetic field.
The discussion is ongoing, with participants providing insights and clarifications about the equations and their applications. Some participants express agreement on certain points, while others raise questions about the assumptions made in the problem statement and the nature of the circuit involved.
There is a noted ambiguity regarding whether the circuit in question is a loop, as the problem statement does not explicitly define it as such. Participants are also considering the effects of varying magnetic fields and the conditions under which the derived equations hold true.
rebc
We're given a situation where the circuit can move under the influence of a magnetic force. Now I need to show that the force on the magnetic dipole is
$$\vec{F} = (\vec{m} \nabla) \vec{B} $$
Could I start from a given Force for a loop with a dipole moment in the B-field, where
$$\vec{F} = \nabla (\vec{m} \cdot \vec{B})$$
and apply the identity $$\vec{F} = \vec{m} \times (\nabla \times \vec{B}) +\vec{B} \times(\nabla \times \vec{m}) + (\vec{m} \cdot \nabla)\vec{B} + (\vec{B}\cdot\nabla)\vec{m}$$
I think your approach is more accurate than the problem statement which needs a dot product in it. And yes, you got the vector identity correct for the gradient of a dot product. ## \vec{m} ## is a constant so vector derivative operations on it are zero. Also ## \nabla \times \vec{B} =0 ## for the steady state where no currents are present. (Comes from Maxwell's ## \nabla \times \vec{B}=\mu_o \vec{J}+\mu_o \epsilon_o \dot{\vec{E}} ## . Any currents from ## \vec{m} ## don't count as part of ## \vec{J} ## because ## \vec{B} ## is the external field applied to the ## \vec{m} ##.) Thereby, you have successfully showed the necessary result which is ## \vec{F}=(\vec{m} \cdot \nabla ) \vec{B} ##.
The problem statement does not necessarily say though that the circuit is a loop. The first equation explicitly states that it applies to a loop in a magnetic dipole. Can I still apply such equation for some circuit where a circuit element of it is under some magnetic field?
And thank you, and yes, $$\vec{F}=(\vec{m}\cdot\nabla)\vec{B}$$
A magnetic dipole is a loop of current. ## \vec{m}=I \vec{A} ## where ## I ## is the current and ## \vec{A} ## is the area (points normal to the loop), sometimes with an extra constant factor depending upon the system of units. The equation will also work for a loop of current in a circuit, but works better for smaller loops. If the field changes too quickly across the loop/electrical circuit, it's more accurate to then compute the force by integrating ## d\vec{F} =I \, d\vec{l} \times \vec{B} ## around the loop. ## \\ ## The equation also applies to the force on a permanent magnet which is a large (sometimes nearly uniform) distribution of magnetic dipoles throughout the material. The magnetization ## \vec{M} ## is the density of magnetic dipoles per unit volume. As long as the magnetization ## \vec{M} ## is unaffected (approximately) by the applied field, you can use it to compute the force on a permanent magnet in a magnetic field. In this case you need to sum/integrate the forces ## d \vec{F}=(\vec{M} \cdot \nabla) \vec{B} \, d^3x ## over the volume of the magnet.
Let me edit the last equation to show the ## \vec{x} ##-dependence: ## d\vec{F}=(\vec{M}(\vec{x}) \cdot \nabla )\vec{B}(\vec{x}) \, d^3 \vec{x} ##.
  • · Replies 25 ·
  • · Replies 31 ·
