Find the Magnitude of Emf Induced in a Circular Loop After 6.00s
A circular loop of iron wire with an initial circumference of 166 cm is decreasing at a rate of 13.0 cm/s while in a uniform magnetic field of 1.00 T. The task is to calculate the induced emf after 6 seconds, considering the changing circumference and area affecting magnetic flux. The initial calculations led to an emf of 0.00190 V, but this was marked incorrect due to not accounting for the decrease in area and flux properly. The discussion highlights the need to reassess the relationship between the changing circumference, area, and induced emf. Clarification on entering mathematical symbols in the assignment platform was also requested.
Charanjit
1. Homework Statement :
A circular loop of flexible iron wire has an initial circumference of 166cm , but its circumference is decreasing at a constant rate of 13.0cm/s due to a tangential pull on the wire. The loop is in a constant uniform magnetic field of magnitude 1.00 T, which is oriented perpendicular to the plane of the loop.
Question: Find the (magnitude of the) emf induced in the loop after exactly time 6.00 s has passed since the circumference of the loop started to decrease.
2. Homework Equations :
Flux= Close integral(B*dA)
e=(d/dt)Flux
3. The Attempt at a Solution :
C(t)=C0-at = 1.66-0.13(6.00)=0.88m
0.88=2pi*r --> pi*r=0.44
e=pi*rdrB = 0.44(1)(0.130m/s)/2pi = 0.00190V
Since I am using web assign, it said this was incorrect. and gave me feedback which stated: A decrease in the circumference of the loop will also cause a decrease in the area and hence the magnetic flux. This will induce an emf in the loop.
Hmm... seems like two things are chaning the circumference and the area. So where am I wrong, and what should I do?
Edit: Also are there ways to enter integral sign and other things here?
Anyone help on this?
Hello?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
