Exploring Shuttle Foam: Composition, Application, and Manufacturer Info
  • Thread starter Spin_Network
In summary, the Space Shuttle External Tank uses a variety of spray-on foam to protect it from the elements. This foam can be troublesome, as it can be lost during lift off. There is a need for improved foam technology to reduce losses.
Spin_Network
376
Anyone have details on the Foam, ie its composition..some data on its manufacturer..anything on how it is applied to the Shuttle External Tank would be great. I have an idea on the foam braking away during lift off, but this is purely based on factors I have been trying to tackle with, that are not stress related, so until I know everything about the Foam and how it is applied to the tank, it won't make any sense.
Any tech links would be greatly recieved, thanks.
Most of the External Tank is insulated with three types of spray-on foam. NCFI 24-124, a polyisocyanurate foam applied with blowing agent HCFC 141b hydrochlorofluorocarbon,is used on most areas of the liquid oxygen and liquid hydrogen tanks. NCFI 24-57, another polyisocyanurate foam applied with blowing agent HCFC 141b hydrochlorofluorocarbon, is used on the lower liquid hydrogen tank dome. BX-250, a polyurethane foam applied with CFC-11 chlorofluorocarbon, was used on domes, ramps, and areas where the foam is applied by hand. The foam types changed on External Tanks built after External Tank 93, which was used on STS-107, but these changes are beyond the scope of this section.
- from http://anon.nasa-global.speedera.net/anon.nasa-global/CAIB/CAIB_lowres_chapter3.pdf
I believe this is from the CAIB report, but I haven't confirmed it.
See also - http://en.wikipedia.org/wiki/External_Tank
and - Modification of Space Shuttle Tiles? - post 11
He's good like that ;-)
So are you Fred :wink:
Spin_Network said:
A very generous array of links and data, many thanks.
There is also some useful photos showing how the complexity of the Space Shuttle External Tank at - http://www.nasa.gov/centers/marshal...lery/photos/photogallery/shuttle/shuttle.html
The major problem for the foam is the PAL area and Bipod region. The Bipod area creates significant turbulence - vortex shedding off the cylindrical structures.
It appears that the area on ET-121 (on STS-114, Discovery), which lost the foam, was a patch and blend repair. There is definitely a need for improvement in this area.
In reality, the foam loss is only significant on the shuttle side of the tank or roughly 1/3 of the circumferential surface. A kevlar mesh with about 5-8 cm pitch and located just below the surface of the foam would seem reasonable to ensure a reduction in foam loss - but perhaps easier said than done.
Related to Exploring Shuttle Foam: Composition, Application, and Manufacturer Info
1. What is shuttle foam made of?
Shuttle foam is primarily made of a composite material called polyurethane, which is a type of plastic. It also contains other materials such as aluminum and glass fibers for reinforcement.
2. How is shuttle foam applied to the spacecraft?
Shuttle foam is applied in a liquid form and then expands into a foam when it comes into contact with air. It is applied to the exterior of the spacecraft using a spray-on method and then allowed to cure and harden.
3. Who manufactures shuttle foam?
The shuttle foam used in NASA's space shuttles was manufactured by Lockheed Martin. However, after the retirement of the shuttle program in 2011, NASA began using a different type of foam made by a company called Orbital ATK.
4. What are the properties of shuttle foam?
Shuttle foam is lightweight, strong, and has good insulation properties. It is also resistant to heat, chemicals, and radiation, making it suitable for use in space exploration.
5. How has shuttle foam been improved over time?
Since the tragic Columbia disaster in 2003, NASA has made several improvements to shuttle foam to prevent any future incidents. These include the use of a more durable foam, changes in the application process, and better inspection and testing methods.
  • Mechanical Engineering
  • STEM Academic Advising
  • Set Theory, Logic, Probability, Statistics
  • Aerospace Engineering
