Sierpinskis Gasket - Linear Algebra
Upsidealien
Where
:- ∆0 = ∆ is the original triangle ABC.
:- DEF are the midpoints of AB, BC, AC respectively.
:- f1, f2, f3 map the triangular region ABC to the triangular region ADF, DBE and FEC respectively.
:- ∆n+1 = f1(∆n) ∪ f2(∆n) ∪ f3(∆n) for n≥0.
(these are just definitions of Sierpinskis gasket)
1. We need to first sketch ∆1 and ∆2 and prove that ∆n+1 ⊆ ∆n for all n ≥ 0.
We then define S = intersection of ∆n from n=1 to ∞.
2. We then need to prove that S is non-empty and that S = f1(S) ∪ f2(S) ∪ f3(S).
Given above.
I attempted 1. by using induction but did not get very far and for 2. I have proved that S ⊇ f1(S) ∪ f2(S) ∪ f3(S) but I am struggling to prove S ⊆ f1(S) ∪ f2(S) ∪ f3(S) Thanks
Tom
So you basically at the n+1 step map the n-th triangle to three of its interior triangles, and leaving the middle triangle intact. Doesn't this by itself prove the inclusion, even proper inclusion.
For the intersection, take x\in S thus for every n \geq 1 x is in delta(n), thus x\in f_1(\Delta n)\cup f_2(\Delta(n)\cup f_3(\Delta(n)) for every n>0, thus you can keep iterating it ad infinitum, thus x\in f_1(S)\cup f_2(S)\cup f_3(S).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
