Significance of kinematic and dynamic viscosity
Kinematic viscosity is defined as the ratio of dynamic viscosity to density, serving as a convenient term in fluid mechanics. It simplifies equations, particularly in the context of the Reynolds number, where \mu/\rho terms appear frequently. Both viscosities measure how momentum is diffused through a fluid, with kinematic viscosity specifically acting as a diffusivity constant. The discussion highlights the analogy between the heat equation and the Navier-Stokes equations, emphasizing the role of kinematic viscosity in momentum transfer. Understanding these concepts is crucial for analyzing fluid behavior in various applications.
Waqar Amin
It is stated that kinematic viscosity is the ratio of dynamic viscosity to density. can anyone elaborate it further that what are the uses of both types of viscosities and why we differentiate them.does dynamic viscosity reates with static fluid?
It is really just a term of convenience. Oftentimes, the equations of fluid mechanics are manipulated such that you end up with \mu/\rho terms, so it is simply much easier to carry around a \nu instead of a fraction. This is commonly seen with the Reynolds number, which has a \mu/\rho term in it.
then how kinematic viscosity is termed as momentum diffusivity, i m very confused with these terms.
Well, as with any sort of viscosity, it is really a measure of how momentum is diffused through a fluid. If you are familiar with the heat equation, you should notice some analogs between it and the Navier-Stokes equations.
The heat equation:
\frac{\partial \phi}{\partial t} = c^2\nabla^2 \phi
The incompressible Navier-Stokes equation:
\frac{\partial \mathbf{v}}{\partial t} + \mathbf{v}\cdot\nabla\mathbf{v}=-\frac{1}{\rho}\nabla p + \nu\nabla^2\mathbf{v} + \mathbf{f}
The heat equation is a simplified version of the diffusion equation that describes the diffusion of basically any quantity through a material. In heat transfer, c^2=\alpha=\frac{k}{\rho c_p} is the thermal diffusivity.
In the Navier-Stokes equations, notice that the \nu\nabla^2\mathbf{v} term takes the same form, only the N-S equations are a momentum balance, so the kinematic viscosity, \nu, is essentially a diffusivity constant that describes how momentum diffuses through the medium. In other words, it describes one particle's ability to affect the momentum of the adjacent particles.
i have understand. thanxx for your help boneh3ad. :)
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
