Simple 1VDC Relay Circuit for Low-Power Device Control | DIY Electronics
  • Thread starter Thread starter arcadefreaque
    Circuit Relay
The discussion revolves around designing a simple relay circuit for controlling a low-power device using a cell phone's vibration motor's power source. Participants explore the feasibility of using a transistor instead of a relay, given the low voltage output from the phone, and discuss circuit design considerations, including grounding and protection against voltage spikes.
  • One participant expresses a lack of experience in electronics and seeks advice on controlling a device powered by 3.6vdc using a 1-1.3vdc trigger from a cell phone.
  • Another participant suggests using an NPN transistor to control the motor instead of a relay, indicating that 1V is too low for most relays.
  • A participant confirms their understanding of the transistor circuit and emphasizes the importance of tying the grounds of the two devices together.
  • There is a discussion about including a diode in the circuit to protect the transistor from voltage spikes when driving the motor.
  • One participant questions whether the phone output signal is DC or pulsed, noting that it appears to be DC but turns on and off quickly when the phone vibrates.
  • A participant mentions that their application will control the power on and off through software, rather than relying on the phone's default pulsing behavior.
Participants generally agree on the use of a transistor for the circuit design and the necessity of including a diode for protection. However, there is uncertainty regarding the nature of the phone's output signal and its implications for the circuit operation.
Participants have not fully resolved the specifics of the phone's output characteristics, such as whether it is purely DC or has pulsing behavior, which may affect the circuit design.
arcadefreaque
Okay, admittedly I am not that well versed in electronics. I can solder and follow directions well enough to put together some interesting hacks occasionally, but I'm really a greenie when it comes to certain aspects.
I'm trying to find a reasonable way to accomplish turning on and off a device that is powered by about 3.6vdc. The trigger mechanism would be a cell phone's vibration motor's power source (motor disconnected) which outputs somewhere around 1 - 1.3vdc.
I started this project by using a simple relay circuit controlled by a serial port of a computer, but now want to move it to the cellular angle - which gives me much lower power output unless I go with some sort of bluetooth serial adaptor (which I'm working on as well). For now though, if anybody has ideas on a simple scenario for a quick switching relay circuit that would work for this scenario, I'd really appreciate the assistance.
Thanks
I'm not real comfortble with this question. Thread locked for a bit...
Okay, after some side discussion, I'm re-opening the thread.
1V is really too low to run much of a relay, but plenty to turn on a transistor. Just use an NPN transistor to ground as your switch. Take your output and drive the base through a resistor, ground the emitter, and put the collector to one side of the motor. The other side of the motor goes to your battery + supply.
Okay, this sounds do-able. I've attached a really cheesy drawing of what I believe that you're describing. Basically confirming that I need to tie the grounds of the two devices together, and treat the output of the collector as the "ground" for my motor being driven, and attach the motor directly to the positive side of the power supply.
I'd read that if I'm driving a motor from this circuit that I should probably include a diode between the 3.3vdc+ and the output of the collector so that the transistor is protected from any spikes, would you agree with this summation?
Thanks a BUNCH for your advice :)
https://www.physicsforums.com/attachment.php?attachmentid=23210&stc=1&d=1264018597
Well done. And yes, a diode across the motor is a good idea, with the cathode to the + terminal and the anode to the - terminal. Do you know if the phone output signal is DC or pulsed?
Thank you!
It appears that power is dc power but it turns on and off quickly when the phone rings in vibrate mode. This is a function of the software from what I can tell. My application will actually be a piece of software running on the phone, so I will be turning the power on and off as needed rather than letting it pulse from the ringer's logic routine. I'll have to test this tonight by running the app and measuring the output when I am directly driving it, to be sure.
  • · Replies 18 ·
  • · Replies 20 ·
15K
