Calculating the Maximum Energy Stored in a Compressed Spring
  • Thread starter Thread starter Stroodle
    Compression
To calculate the maximum energy stored in a compressed spring, the correct formula is E_e = (1/2)kx^2, where k is the spring constant and x is the compression distance. The spring constant provided is 5.0 x 10^5 Nm^-1, and the compression distance is 8 cm (0.08 m). Plugging in these values results in an energy calculation of 2.0 x 10^5 J. However, there is a discrepancy with the book's answer of 1.6 x 10^3 J, indicating a possible error in the problem setup or interpretation. Clarifying the problem statement may help resolve this inconsistency.
Stroodle
Hi there,
For this question, I've been asked to calculate the maximum energy a spring can store when compressed by 8cm. I've already found the spring constant to be 5.0\times 10^5\ Nm^{-1} (which is correct), so I thought it was just a simple matter of pluggung the values into the formula: E_e=\frac{1}{2}kx^2
When I do this I get the answer: 2.0\times10^5\ J, but the book says the answer is 1.6\times10^3\ JThanks for your help
Please post the full text of the problem.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
