Solving Y=\sqrt{x}(x-1) Derivitive
  • Thread starter cscott
In summary, the conversation discusses how to deal with the square root in the equation y = \sqrt{x}(x - 1) and the formula for deriving powers of x. It is suggested to distribute the square root and then take the derivative. The correct way to write 1.5 is as \frac{3}{2} and it is recommended to use improper fractions instead of mixed fractions for simplicity.
cscott
782
How do I deal with the square root in [itex]y = \sqrt{x}(x - 1)[/itex]?
[tex]\sqrt{x} = x^{(\frac{1}{2})}[/tex]
Distribute and take it away.
Also, remember that [tex]a^x*a^y=a^{(x+y)}[/tex]
You know the simple formula for deriving powers of x, right? Well, [itex] \sqrt{x}=x^{\frac{1}{2}}[/itex]
EDIT: I was slow. Sorry, I didn't mean chain, I meant distrubution for derivation (didn't know what you call it in English).
Can I get any further that here?
[tex]\left(x - 1\right)\left(\frac{1}{2\sqrt{x}}\right) + \sqrt{x}[/tex]
You're making it more complicated than neccessary.
Distribute the [itex]\sqrt{x}[/itex] then take the derivative.
Ok, your way works, but I wouldn't do it that way. That's the beauty of it though, many correct ways to get the same answer.
[tex]1\frac{1}{2}x^{\frac{1}{2}} - \frac{1}{2}x^{-\frac{1}{2}}[/tex]
correct?
First part is incorrect, second part is correct.
Hmm I don't see how :frown:
[itex]x^{\frac{1}{2}} \cdot x^1 = x^{1.5}[/itex] so doesn't that become [itex]1.5 \cdot x^{\frac{1}{2}}[/itex]?
Oh, ok. You were righting a mixed fraction. It would be best to write 1.5 as [itex]\frac{3}{2}[/itex]
Try not to use mixed fractions, they get too confusing. Use improper ones.
For example: take the derivative of [tex]3\frac{1}{2}\frac{5}{7}x^4[/tex] with respect to x. Make sense?
Jameson said:
Oh, ok. You were righting a mixed fraction. It would be best to call 1.5 [tex]\frac{3}{2}[/tex]
Try not to use mixed fractions, they get too confusion. Use improper ones.
Thanks for the tip and your help (Berislav too) :smile:
What is the formula for the derivative of Y = √x(x-1)?
The formula for the derivative of Y = √x(x-1) is:
Y' = (1/2√x) * (x-1) + (√x) * (1)
Y' = (√x - 1)/(2√x)
How do you find the derivative of a square root function?
To find the derivative of a square root function, use the following formula:
f'(x) = 1/(2√x) * f(x)
What is the rule for finding the derivative of a product of two functions?
The rule for finding the derivative of a product of two functions is the product rule:
(fg)' = f'g + fg'
Can you simplify the derivative of Y = √x(x-1)?
Yes, the derivative of Y = √x(x-1) can be simplified to:
Y' = (√x - 1)/(2√x)
How can the derivative of Y = √x(x-1) be used in real-world applications?
The derivative of Y = √x(x-1) can be used in many real-world applications, such as calculating the rate of change in a system, determining maximum and minimum values, and solving optimization problems.
