Simple harmonic motion (4 questions)
The discussion revolves around four physics problems related to simple harmonic motion (SHM). The first problem involves calculating the amplitude of SHM and the fraction of kinetic energy converted into mechanical energy after a bullet embeds into a block. The second problem focuses on estimating the spring constant and damping coefficient for a car's suspension system based on its sag and oscillation characteristics. The third problem examines how much a car rises on its suspension after passengers exit, considering the car's weight and road conditions. The final problem discusses the dynamics of a mass on a string, highlighting that it does not exhibit SHM due to the large angle of displacement, and asks for calculations of velocity and tension at specific points. Overall, participants seek assistance with understanding and solving these complex physics problems.
jin
1. A 4.0kg block is suspended from a spring with force constant of 500N/m. A 50g bullet
is fired into the block from directly below with a speed of 150m/s and is imbedded in
the bloack. (a) Find the amplitude of the resulting simple harmonic motion. (b) What
fraction of the original kinetic energy of the bullet appears as mechanical energy in the
harmonic oscillation?
2. Assume that you are examining the characteristics of the suspension system of a 2000kg
automobile. The suspension “sags” 10cm when the weight of the entire automobile is placed
on it. In addition, the amplitude of oscillation decreases by 50% during one complete
oscillation. Estimate the values of k and b for the spring and shock absorber system of one
wheel, assuming that one wheel supports 500kg.
3. A 2200lb car carrying four 180lb people drives over a rough “washboard” dirt road with
corrugations 13ft apart. The car bounces with maximum amplitude when its speed hits
10mi/h. The car now stops and the four people get out . By how much does the car rise
on its suspension owing to this decrease in weight?
4. A small mass with m = 100 grams is attached to a vertical string of length l = 2m in
the earth’s gravity. The mass swings back and forth with no loss of energy. The maximum
angle from the vertical is 45. This problem is not simple harmonic motion because the
maximum angle of displacement is not small. Find the velocity when the string is vertical,
 = 0. Find the tension in the string at  = 0. What is the velocity at  = 0 if you assume
simple harmonic motion?
need help studying for it..please help! thx
You should post this in the HWK help section! Also, what have YOU done on these problems so far? What are you stuck on? How far have you got?
for #2 i didn't get part a...i just found the amplitude using A = sqrt((x^2) + ((v^2)/(w^2)) but i heard I'm suppose to be solving for y? the others I'm just totally confused @@
