Simple harmonic motion of a particle
A particle initially at 0.270m with a velocity of 0.140m/s and acceleration of -0.320m/s² moves with constant acceleration for 4.50s. To find the position and velocity at the end of this interval, the equations of motion can be applied. After this period, the particle transitions to simple harmonic motion with its equilibrium position at x=0. The position and velocity at the end of the harmonic motion interval can be determined using the equations for simple harmonic motion, requiring the initial conditions from the previous calculations. The discussion highlights the need for clarity in applying the correct equations for both scenarios.
~christina~
A particle moves along x-axis It is initially at 0.270m moving with velocity of 0.140m/s
and acceleration of -0.320m/s^2
Suppose it moves with constant acceleration for 4.50s.
Find it's:
a) position and velocity at end of time interval
next assume it moves with simple harmonic motin for 4.50s and x= 0 is it's equillibrium position.
Find it's:
b) position and velocity at end of this time interval
x(t)= A cos (\omega t + \phi )
v(t)= - \omega A sin (\omega t + \phi )
a(t)= - \omega ^2 A cos (\omega t + \phi)
well I know for the first situation that:
x_o= 0.270
v_o= 0.140m/s
a_o= -0.320m/s^2
and the acceration remain constant for 4.50s
to find a) the postiion and velocity at end of time interval...
I was thinking that I would take the period (T) to equal T= 4.50s?
and would I use 4.51 seconds and use the velocity as a function of time equation
though I need the \phi...hm..
and I think I'm lost here.
can someone Please help me out with this?
so, a) it's no problem as is an 1 dimension problem, with movement equations...
about b), it's a whole new problem:
you will need to know the position and velocity at t_0=4.50
so, you can write: t_1=0 at x_1=0(equilibrium point)
by a), you calculated velocity at t_0, so, it's the particles velocity at t_1
I guess this should help...
