Simple Harmonic Motion and frequency of a spring
The discussion centers on understanding the quality factor (Q) of a spring-mass system undergoing simple harmonic motion (SHM). Q is defined as a measure of the system's damping, with higher values indicating less damping and longer-lasting oscillations. The system described involves a 2 kg mass attached to a spring, which extends 2.5 cm under the load, and oscillates with an amplitude of 1 mm. To determine the angular frequency, the spring constant can be calculated from the extension, and Q can be used to find the damping constant. The conversation emphasizes the relationship between Q, angular frequency, and damping in the context of SHM.
kidia
I have one question here,I fail to understood what is Q of the system,is anybody has an ideal on this?
An object of mass 2 kg hangs from spring of negligible mass. The spring is extended by 2.5 cm when the object is attached. The top end of the spring is oscillated up and down in SHM with amplitude of 1 mm. The Q of the system is 15.
What is angular frequency for this system?
"Q" is just a symbol until it is given a definition. What does your book say about it? What do your class notes say about it?
The system will certainly not execute SHM. It is driven by gravity.
What have you tried so far?
Sounds like Q is the frequency.
Q is the quality factor. it is an indirect measure of the damping. A large Q means that the damping is small, the oscillation takes a while to die off (assuming no external force of course).
If I recall, Q = { \omega_d \over (b/m) }= {m \omega_d \over b}
where \omega_d \approx \omega_0.
From the fact that spring extends 2.5 cm with a mass of 2 kg you can find the spring constant. So you know omega_0. Knowing Q then gives you a way to find the damping constant. I am not sure about the rest of the steps, though...
Pat
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
